Power brake issues
Okay guys, I have a brake issue. I have a 70 Cuda with power brakes, I recently switched my rear drums to disk. Bled the brakes a bunch of times and got them good and stiff. When I start the car and press the pedal, it goes to the floor. Re-bled (no signs of air in lines) and the same thing. Shut the car off an pump the pedal 2-3 times and it's stiff again. I'm leaning towards the boosters bad. Any ideas?
Thanks. |
CC -
Do you have a break cylinder proportioning valve and if so did you reset it for the new discs? Archer |
I do have a prop valve installed. I didn't reset it though. Not sure how to do that.
Did you put a disc brake master cylinder in? I believe the drum brake MC will have a residual valve in it on the front/forwardmost port.
Originally Posted by Drag Pak
(Post 126610)
Bought the rear disc set up from Right Stuff. they say its a bolt on kit and shouldn't need to change any of the other components. |
I seem to recall the same issue. Fought it for several tries to resolve. I had to put a 2 lb residual valve in my manual rear disc brakes to get them happy. Although on a drag car we run the MC outlets reversed due to the skinny front tires, and no proportioning valve.
Are you bleeding from rr, to lr, to rf, to lf? |
If your booster is OK and you have enough vacuum here's the way to tell. Get in the car and push the brake pedal a few times to expell any residual vacuum that may be present in the booster. Holding the pedal down lightly with your foot, start the car. The pedal should push back towards you but not fully. If this does not happen a booster rebuild is probably required. Do not toss good money away for nothing so go here for the complete story
http://forums.hotrod.com/car-craft/7...brake-booster/ |
the calipers have the bleeders at "very top" ? some calipers can be reversed left to right side, putting bleeder "down"
"what" are these calipers? what sort of setup for emergency (parking) do they have? |
u need a master cylinder designed for 4 wheel disk
Originally Posted by Rooty
(Post 126618)
Originally Posted by moparted
(Post 126672)
Originally Posted by DDodger
(Post 126632)
Originally Posted by Chaotic cuda
(Post 126722)
The master cylinder has nothing to do with what kind of brakes you have. It pushes out the same pressure from both ports. The prop value is what regulates the pressure.
If the pedal goes down, then perhaps the clearance between the master and booster rod is too shallow or the weight of the pedal is causing booster actuation inadvertently. I've seen this happen before and some people put a spring on the pedal arm to ensure it returns to the upper bumper completely. Pedal ratio is quite different for various braking schemes - manual, power, hydra boost and different bores of master cylinders which have varying strokes. This may not be your case but ensure above all else that the master retracts completely. You can measure the stroke depth of the piston when bleeding the master but it's hard to tell weather said piston is pushing back on the booster pin or not. Care full measuring is required to find this gap and the pedal must be held back completely. Perhaps your just not moving enough volume of brake fluid to actuate both front and rear pistons or your line plumbing is not correct. Good luck and don't get frustrated because there's always an answer - you just need to find it.
