1991 Dodge Dynasty Fuel Pump Issues
Old 08-17-2014, 11:39 AM
Dustin LaRoche's Avatar
Exclamation 1991 Dodge Dynasty Fuel Pump Issues
The car died on me a week ago due to a failed fuel pump. I have since ordered one, and put it in, however, I still can't keep the car running.
It will sometimes start but then die a 1-10 seconds later. I'm sure I am not getting enough fuel pressure.
I just replaced the fuel pump motor, and did not opt for an all new fuel pump assembly.
Is there a trick to putting the pump in the assembly to restore full fuel pressure? I have the bottom pump screen/nipple inserted into the the rubber grommet on the bottom of the assembly housing, and the outlet nipple from the top of the fuel pump motor going into the outlet tube on the top of the assembly. For some reason, I can't get it to push out at a decent enough pressure to run the car appropriately.
jhart21
08-28-2022 11:48 AM
switherow
08-28-2014 11:57 AM
99dakota440
06-11-2012 04:16 PM
stazja01
01-15-2009 08:36 PM
stazja01
01-02-2009 09:50 PM
Quick Reply: 1991 Dodge Dynasty Fuel Pump Issues
