Jacking 93 LeBaron
Jacking 93 LeBaron
Hope this is the right spot, looks pretty quiet.
I need to change both rear rims. Can I use the center of the rear axle as a jack point to lift the whole back up at once?
It looks solid enough, but it doesn't hurt to check.
Thanks, Gary
Thanks, Gary
IIRC, They are FWD... could be wrong.
you need to jack one side up at a time. There are lift points (the frame, or a thicker metal piece) for jacking the car up.
Always use jack stands.
Iknow its a dead thread, but it'll help others out in the future.
