99 Chrysler Cirrus won't shift into 4th gear
Old 02-19-2014, 01:55 AM
Jeff Olenski's Avatar
I just bought a 99 Chrysler Cirrus yesterday with an automatic transmission and 159,000 miles. It won't shift into 4th gear when in drive. It shifts from low to 2nd to 3rd just fine, but won't go into 4th. Cruise and speedometer work fine. Is there some kind of overdrive button that I haven't found yet? If not, any idea what could be wrong with it?
Old 09-02-2016, 07:58 AM
Nadir Point's Avatar
I would first try observing the trans linkage from the engine compartment while somebody engages the shifter through the detents to ensure it is moving smoothly throughout the range of motion.
Old 09-05-2016, 11:14 AM
I hope you didn't get the 2.7 V6 even the 4 cyl had oil leaks from the head gasket Have you checked to make sure you have a 3sp /OD trans
Old 09-05-2016, 11:17 AM
OP is over two years old, I'm sure he's got it handled by now!
Old 09-05-2016, 05:03 PM
Let's start a new thread on why we hope against the 2.7!!
AllyRat31
01-27-2015 09:38 AM
Chryslercirrus1995
12-26-2013 06:01 PM
matt760
12-22-2013 03:14 PM
Desperota 488
07-20-2013 03:58 PM
BIGCJ
10-01-2010 05:29 PM
Quick Reply: 99 Chrysler Cirrus won't shift into 4th gear
