ABS problem
Old May 20, 2009 | 01:01 PM
scotts74birds's Avatar
Question ABS problem
The ABS light came on in my 99 Cirrus. My code scanner wont read ABS faults. Is there a way to troubleshoot the system without a dealer?
Old May 20, 2009 | 05:16 PM
Nevermind, found the flexible line at the wheel had collapsed, acting like a bad caliper.
Old May 22, 2009 | 10:07 PM
well, we both learned some thing here, pass it on. If you have a bad caliper, crack the bleeder. If the caliper retracts , its not the caliper. Check the flexible brake line, they do go bad.
Old May 26, 2009 | 10:44 PM
FYI, the line did not go bad. The clamp that holds the line in place corroded, and the rust came in layers, and slowly crimped the brake hose! Pedal pressure will get the fluid past, but it wont go the other way! Big heads up cause heard this is also a Neon issue on front calipers.
lady blue
Aug 20, 2015 07:31 PM
lady blue
Aug 19, 2015 12:53 PM
Brian Grosshans
Aug 18, 2013 05:33 PM
StanH
Dec 15, 2008 08:35 PM
