Go Back   Mopar Forums > LATE MODEL FWD & AWD MOPARS > Intrepid/Concord/Vision/300M
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 07-21-2008, 02:59 PM   #1 (permalink)
doug2060
Junior Member
1994 Intrepid Clunking Noise?
Hello, I'm having a very annoying problem with my 94 Intrepid 3.5 V6 Automatic. I keep hearing this clunking noise anytime I run over a bump in the road. I can only faintly feel it through the steering wheel (unless I'm imagining that I feel it). I have already replaced the inner tie rod bushings with no luck (They were very worn and still needed replaced). It doesn't do it when turning or from stop and go, just a light clunk clunk clunk when I go over even the slightest bump or crack. I honestly feel like it's coming from directly in front of me when driving instead of being a strut or outer tie rod but I can't be sure. It doesn't start until I get past 20 to 30MPH. I want to say it may be the steering rack mount bushings located at either end. I had my 5yr old turn the wheel back and forth and the rack will move from side to side. Even more so when she turned the wheel toward the driver side than when she would turn it to the passenger side. The wheel doesn't feel like it has any play in it. Should it do that? Just by looking at the rack and it's position, it looks like a poor design. I wouldn't trust it in a go cart by looking at it. Has anyone had this problem or any ideas what I should be looking for? Any help is much appreciated. I don't want to keep throwing money at it... Thanks...
doug2060 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
1994 Dakota intermittent misfire David Blair New Member Section 3 05-16-2008 10:21 AM
Intrepid ES heavilly modded TCPMeta Intrepid/Concord/Vision/300M 4 06-04-2007 07:03 PM
Electrical problem with 2000 Intrepid TCPMeta General Technical Questions 0 03-28-2007 05:27 AM
1998 Intrepid 3.2 TyDyed General Technical Questions 3 03-08-2007 07:55 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
