Go Back   Mopar Forums > LATE MODEL FWD & AWD MOPARS > Intrepid/Concord/Vision/300M
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 06-14-2008, 12:23 PM   #1 (permalink)
ron 97 vision
Junior Member
97 vision with auto stick
hello hope someone can help. I have a 97 vision with auto stick that has been a great car. just thursday the trans gave me a big problem with no indication that anything was going wrong. I was sitting in drive and deciced to back up, put car in reverse and heard a clunk-now all I have is 1st gear. If I use auto stick 1st, trans seems fine, shift to 2nd it is like neutral. does the same in drive, as soon as it shifts it is like neutral. fluid is nice and clear, is full. No reverse or any other gears, just 1st-anyone have a hint on how to diagnose the problem? is it a control module bad? mechanical problem? any help would be great.
ron 97 vision is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
its a stick situation greaterprophet Do-It-yourself Section 0 04-10-2008 06:55 PM
Any good auto shops in Minot, ND? bkreke General Discussion 2 04-02-2008 09:14 PM
1969 Roadrunner 383 Auto Posi rear red2bunkeru Mopar Classifieds 1 11-27-2007 02:15 PM
1996 Eagle Vision w/ Check Engine codes 12 and 43 chlfan New Member Section 1 05-29-2007 01:32 PM
1996 Eagle Vision w/ Check Engine codes 12 and 43 chlfan General Technical Questions 0 12-09-2006 07:57 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
