Go Back   Mopar Forums > LATE MODEL FWD & AWD MOPARS > Intrepid/Concord/Vision/300M
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 06-04-2007, 07:12 PM   #1 (permalink)
TCPMeta
Junior Member
EGR delete guide for 3.2L/3.5L
3.5L engines, EGR systems were incorporated to decrease emissions and increase gas mileage. The system was deemed unnecessary and it did not show up on later model engines.
The EGR works by expelling exhaust gases into the back of the upper intake manifold. This hurts performance for three reasons. First, it decreases the amount of fresh air entering the engine. Second, it increases the temperature of the air charge, and three, it adds crudded up junk to the intake. You can see this if you have ever removed your intake plenum.
This system can be disabled without throwing a code.
1. Remove the plenum
2. Cut a section of tubing on both sides going from the EGR solenoid to the plenum
3. Cap all four open tubes
3. Cap all four ends
This is a schematic of the EGR system taken from the FSM.
This picture shows the severed and capped EGR tube coming out of the driver's side of the plenum.
Just below the fuel line and heater hose you can see the EGR tube. It is capped and hose clamps on both ends.
This is a picture from the passenger side of the vehicle. It shows the capped EGR tube. On the extreme left side of the picture you can see the EGR valve itself and the metal tube which connects the EGR valve to the EGR tube.
TCPMeta is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
