Belt drive
Hey all .. I just received the latest Jeggs email and comp cams has a belt drive gear set priced over $400
I think they are crazy and someone who buys it even crazer u got to have more disposable cash than sense.. what do you think? |
well as a po guy i won't be buyin' one. on the other had, you do this.........you take a modern vehicle, strip off the belts, pulleys, brackets and bolts, ALL of them and go down 'n price 'em at the dealer, and then you let me know how that all goes
Test proven to be worth it in the racing world..... Horse Power Cost Money..:)
my pappy allways said it cost money to go fast "how fast do you want to go? how much money do you have. its the same Q"
How much hp.will that drive add a 10th of a hp
any tork maybe a lb i dont see a justification for such.a cost and how long will it last it most likly costs less in materials too manufacture that than a standard chain and gears |
Originally Posted by moe7404
(Post 126807)
And I bet you have to block off the oil from hiting the system....more cash.. its crazy ! even if I had cash to wipe my azz with I know when im being taken advantage of. |
Does it have an option to run the dist in the front ??
So I guess by your standards.... These Guys are Idiots????
https://www.google.com/search?tbm=is...C8wAA#imgdii=_ |
(Post 126826)
https://www.google.com/search?tbm=is...C8wAA#imgdii=_ major sponsered race team maybe the pics suggest they have tons of sponsered parts and the belt would last as long as one of their motors befor tear down and rebuild 1 maybe 2 runs 10,020 hp if they have cash to spend on a belt good for them ... |
Originally Posted by TVLynn
(Post 126814)
i have never heard of a belt out lasting a chain or gear Maybe racer hog can explain this for us back yard motor heads the value of this system over chain and gear systems .. |
Hummmm... Honda Toyota and Nissan, "Just to name a few" have seem to do just fine with them.
Anyway... I do understand your point of the money issue.... :) |
Originally Posted by Gorts 5th
(Post 126837)
I read the specs they claim its stronger than standrd chain and gears including gear drive systems they also say it soaks up some of the crank harmonics
i have never heard of a belt out lasting a chain or gear Maybe racer hog can explain this for us back yard motor heads the value of this system over chain and gear systems .. No picking on you Gorts... Just turning thinking cap on.... :) |
Ps I typ c a s h and I get that icon w t fric
hahahaha.... We get the point... :):)
Racerhog we are always good
I new you could shed more light on it so in mopars the valve train flex is as bad as with chby and frd. i understand that shaft monted rockers are less suspect to this than pedistal mounted rockers I didnt see a listing for mopar ..if they have one would u use it ? Please exsplain the bennifits of this system for our motors. thanks . ps only saw it listef for chby |
Sure Why not????
https://www.google.com/search?q=2.2+...ml%3B642%3B800 Would you like to buy all the gears for this set up.... Would be kind of expensive dont you think? I believe the belt has test proven them selves to be worthy in the OEM Area? I think also the Race one have proven there place also.... |
My next fresh build is getting one for sure. I certainly wouldn't tear a complete engine apart just to swap one in though.
I think he finally got it... I don't really get the original post, When you are building a performance engine $400 is a small drop in the bucket.... It has always been if you want to play you got to pay... Belt drive is better and if it weren't they wouldn't use it on super chargers.. Timing chain work ok but are not as precise as a belt... Think about it as soon as the chain is installed it starts to stretch as it does the cam timing is able to change... The belt has a tensioner to keep it tight and the cogs keep it in time.. Many of the performance applications the belt is exposed and is a lot easier to change then a chain which requires engine tear down to do.. So if you are racing are building a GO machine then the belt is the only way to go...As Bob has been saying....Bill
Belt Drive? Give me a chain driven or Gear driven timing set any day!!!
Hey all its been awhile.
Ok i got a update on this thread
and im wondering who has used this on their engine? im thinking its a major modification. question....wouldn't you have to stop the oil from coating the belt and associated pullies? im asuming that the above mentioned imports don't alow the oil on there belts. so is this still a worthy investment if major modification is necessary? verses gear or standard double rollers? |
