01 neon rt just dies yet runs like a champ...
Old 09-18-2013, 10:24 AM
ruckusracer15's Avatar
I've looked a little thru this forum but haven't found the same problem i am having... I just picked up a 01 neon rt manual trans new motor and clutch...the car will run perfectly fine,start right up,rev perfectly but as soon as the car starts to roll it will die... Either trying to take off in gear or if you get out and push the car with nobody in it ..if the wheels start to turn it will die.. Any help is appreciated
Old 09-18-2013, 09:56 PM
slade's Avatar
this interesting lol jack it up and spin the wheels see if it dies
Old 09-19-2013, 05:26 AM
Strange ! I would check engine movement , maybe it is pulling on wires ??? Make sure the computer ground connections are tight
Old 09-19-2013, 08:10 AM
That's the first thing ill be doing when i get it to the house only paid 750 for the car its gotta be something stupid
Old 09-19-2013, 08:13 AM
I've looked at most of the wiring when i got the car i haven't brought it home yet but everything looks fine engine move much...hell it can be idling and it'll die when u push it ...weird sh*t
Old 09-19-2013, 03:14 PM
pro-tech's Avatar
Unhook the VSS and see what happens..It is the only link to the computer with movement... Check to make sure there are no wires rubbing on the axles causing a short to ground...Bill
Skwerly
17
03-22-2013 02:35 PM
MReeves
Pro-Stock
11-13-2012 05:21 AM
Tom Wright
03-02-2011 03:12 PM
Monacoman
09-21-2008 04:15 AM
nicolette
12-19-2007 12:13 PM
Quick Reply: 01 neon rt just dies yet runs like a champ...
