Pump Noise
Old 03-18-2012, 01:58 PM
Member
jar84203's Avatar
Pump Noise
I have a 02 Cruiser and after making a U-turn, I notice a whine coming from under the hood. Is this the PS pump and if so why does it whine after the turn is completed and the vehicle is traveling in a straight line? Thanks.
Old 03-18-2012, 04:08 PM
blue 68 gts's Avatar
Possibly low on fluid, have you checked that?
Not sure, but a whacked out theory i came up with, if the valve in the rack got stuck one way, then there would be pressure to one side, nothing on the other. But then I guess that'd make it hard to steer and pull you in one direction or another.
I vote low fluid.
Old 03-18-2012, 05:35 PM
Member
jar84203's Avatar
Fluid is good.
Old 03-18-2012, 05:43 PM
Originally Posted by jar84203
Fluid is good.
Are the lines to the rack kinked?
Sounds like a bad rack or valve or bad pump.
Hard to diagnose noises without driving or having some sort of video..
Old 03-18-2012, 07:37 PM
Member
jar84203's Avatar
Upon visual inspection, everything appears fine (the lines weren't kinked).
Old 03-18-2012, 09:11 PM
I would flush the pump / change the fluid.. Hook a hose to the return line while the engine is running slowly pour fluid in until it comes out clean.. Then reconnect
Old 03-19-2012, 09:32 AM
Member
jar84203's Avatar
I'll try flushing it today. So bad fluid can cause it to become noisy?
doug2060
08-28-2010 04:33 PM
MichaelSB
08-16-2010 12:08 PM
JLanzino
05-01-2009 06:58 PM
Valcam
05-01-2009 03:10 PM
mopar nate
03-21-2009 09:16 PM
Quick Reply: Pump Noise
