318 magnum question
Old 06-22-2009, 01:35 AM
yes, you will need to have the block "bored out" for a larger size piston.
Old 06-22-2009, 08:39 AM
try not to bore out though it the engine doesnt need it
Old 06-22-2009, 05:44 PM
well, check you pressure in each cylinder
if it is ok, you shouldnt do it
Old 07-10-2009, 09:18 PM
fury_19's Avatar
im curious wat the diff is between the 318 and the 318 mag? could u enlighten me?
Old 07-15-2009, 10:31 PM
fury_19's Avatar
Originally Posted by 1973charger
.......i think
yeah i found that out there are 3 dif 318's i think L-A, poly, and mag
Old 07-16-2009, 04:21 PM
poly was the original 318
SPICOLIE203
12-04-2013 10:24 PM
johnboy
02-01-2012 11:20 AM
Scampman
07-27-2011 06:07 PM
MightyMagnum
10-22-2009 10:17 PM
craveman
09-12-2009 10:39 AM
Quick Reply: 318 magnum question
