440 Source Roller rockers
Old 03-03-2009, 10:11 PM
deadkelly's Avatar
are they alloy or stainless steel ?
Old 05-29-2010, 09:22 PM
rexus31's Avatar
I would pull the valve covers every once in a while to inspect them. I read a post on anther site that some people had the pin come loose that holds the roller tip in place and the roller fell off the rocker. This then makes the rocker a pitch fork that will eventully loosen the valve keepers causing a dropped valve. The photos of what happened to the cylinder weren't pretty. I was planning on running their roller rocker setup but went with the stock stamped steel rockers after I read that thread. Just a heads up.
Old 04-07-2011, 09:35 PM
deadkelly's Avatar
i'm not sure what brand my stainless steel comp cams copy's are but i spent 2 day's of intence sanding down the shims . if i were to do it all again i'd spend the extra money & buy comp cams rockers or another good brand . but who knows if ya had to sand there shims i'd be pissed . oh well at leased i have my rollers on the valve stems now ( in the middle )
Old 04-08-2011, 06:30 PM
scotts74birds's Avatar
I too have heard "things" about the 440 source roller rockers on other forums. A close eye is warranted.
Old 04-17-2011, 08:48 PM
Only thing I can report to this date is that they are noisy...I have run their 1.6 ratio rockers for over a year now...I hammer on it every weekend and have had no failure...if I had to do it over again I would have gone with some Harland Sharps..
Old 09-29-2012, 07:53 AM
Chryco Psycho's Avatar
PRW has a nice product as well , all stainless steel roller tip in 1.5 , 1.6 & 1.7 ratio
Old 11-28-2012, 08:09 PM
Banned
Damtom's Avatar
I peruse a post on anther destination that some folks had the pin come detached that keeps the roller tip in spot and the roller tumbled off the rocker. This then makes the rocker a pitch fork that will eventually relax the valve attendants creating a dropped valve.
moparjohnson123456
06-14-2011 01:28 PM
440truck
05-14-2010 08:14 AM
Wonsley69
04-10-2010 09:57 AM
joe440
03-06-2009 04:27 PM
fury413rb
04-17-2007 08:22 PM
Quick Reply: 440 Source Roller rockers
