Crankshaft Mopar Performance 0.040" under
Old 03-06-2009, 07:33 AM
I wouldn't trust any crank that was turned over .030 (even that can be a bit much depending on the motor), but that is just me. How much power are you getting from the motor?
Did you get the crank from Summit Racing damaged?
Old 02-07-2017, 12:58 PM
A competent shop should be able to weld it back to stock size. I'm sure it wont be cheap. Is it cast or forged ? Cast? use it for a door stop...040 under bearings will be hard to find
68Dart
03-17-2019 05:43 PM
1966DartConvertible
08-05-2010 07:58 PM
mystarcollectorcar.com
04-16-2010 03:42 AM
Quick Reply: Crankshaft Mopar Performance 0.040" under
