2012 O'Reilly NHRA Spring Nationals Houston
Fri, 27 Apr 2012, 16:42 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Session #1 By Larry Sullivan http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif BAYTOWN, Texas - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 25th annual O'Reilly NHRA Spring Nationals presented by Super Start Batteries listing lane, driver name, elapsed time, top speed, and position in order following run: Left Lane: Dave Connolly Runs 6.658/210.28, Now #1 Right Lane: Warren Johnson Runs 7.038/207.34, Now #2 3:07 p.m. Weather conditions: air temperature 83 degrees, relative humidity 60 percent, barometer 29.89 inches, adjusted altitude 2,524 feet, track temperature 114 degrees. Both cars had trouble getting off the line, Connolly with a lot of tire spin, while WJ shook, then bogged. Dave Connolly's incremental times: 60ft-1.035 sec., 330ft-2.825, 660ft-4.307/166.58 mph, 1,000ft-5.584. Warren Johnson's incremental times: 60ft-1.125 sec., 330ft-3.125, 660ft-4.650/163.06 mph, 1,000ft-5.950. Left Lane: Rickie Jones Runs 6.629/209.56, Now #1 Right Lane: V. Gaines Runs 7.212/207.75, Now #4 Gaines' car launched about the same as Johnson's, the car shaking and bogging. "The Tricky One" made a clean launch and he's #1, for now. Rickie Jones' incremental times: 60ft-0.997 sec., 330ft-2.784, 660ft-4.270/166.17 mph, 1,000ft-5.551. V. Gaines' incremental times: 60ft-1.256 sec., 330ft-3.287, 660ft-4.823/162.35 mph, 1,000ft-6.125. Left Lane: Chris McGaha Runs 6.663/207.82, Now #3 Right Lane: Steve Kent Runs 6.740/203.37, Now #4 McGaha had a clean launch and a nice run. Kent's car made a couple of quick moves on the launch and that cost him some ET. Chris McGaha's incremental times: 60ft-0.997 sec., 330ft-2.790, 660ft-4.285/165.19 mph, 1,000ft-5.577. Steve Kent's incremental times: 60ft-1.013 sec., 330ft-2.851, 660ft-4.358/164.41 mph, 1,000ft-5.650. Left Lane: Kurt Johnson Runs 6.638/209.17, Now #3 Right Lane: Ron Krisher Runs 6.631/209.69, Now #2 Two clean runs, no visible problems. Kurt Johnson's incremental times: 60ft-1.002 sec., 330ft-2.785, 660ft-4.273/165.88 mph, 1,000ft-5.558. Ron Krisher's incremental times: 60ft-1.009 sec., 330ft-2.791, 660ft-4.275/166.50 mph, 1,000ft-5.555. Left Lane: Larry Morgan Runs 6.650/208.88, Now #4 Right Lane: Shane Gray Runs 6.668/207.46, Now #7 Larry Morgan's incremental times: 60ft-1.008 sec., 330ft-2.795, 660ft-4.283/165.70 mph, 1,000ft-5.567. Shane Gray's incremental times: 60ft-0.994 sec., 330ft-2.790, 660ft-4.286/164.93 mph, 1,000ft-5.580. Left Lane: Jeg Coughlin Runs 6.634/209.85, Now #3 Right Lane: Ronnie Humphrey Runs 6.693/209.17, Now #9 Jeg made a nice first pass, right down the groove. Humphrey had a good launch, but after that he was chasing Coughlin and losing ground. Jeg Coughlin's incremental times: 60ft-1.011 sec., 330ft-2.795, 660ft-4.279/166.29 mph, 1,000ft-5.557. Ronnie Humphrey's incremental times: 60ft-1.002 sec., 330ft-2.810, 660ft-4.319/163.97 mph, 1,000ft-5.612. Left Lane: Rodger Brogdon Runs 6.616/209.30, Now #1 Right Lane: Greg Stanfield Runs 6.677/206.95, Now #10 Stanfield's car was really off the pace on the top end, his speed down about 4 mph. Brogdon made a very nice run to take over as #1. Rodger Brogdon's incremental times: 60ft-0.996 sec., 330ft-2.778, 660ft-4.261/166.46 mph, 1,000ft-5.539. Greg Stanfield's incremental times: 60ft-0.998 sec., 330ft-2.794, 660ft-4.293/164.75 mph, 1,000ft-5.587. Left Lane: Erica Enders Runs 6.598/210.31, Now #2 Right Lane: Vincent Nobile Runs 6.586/210.34, Now #1 With David Connolly driving this weekend, Richie Stevens is acting as "car boss" for Enders this weekend. Both cars made nice, straight, smooth runs to take possession of the top two spots. Erica Enders' incremental times: 60ft-0.991 sec., 330ft-2.769, 660ft-4.250/166.85 mph, 1,000ft-5.525. Vincent Nobile's incremental times: 60ft-0.992 sec., 330ft-2.763, 660ft-4.241/167.22 mph, 1,000ft-5.515. Left Lane: Allen Johnson Runs 6.554/211.93, Now #1 Right Lane: Mike Edwards Runs 6.599/210.37, Now #4 Two more strong runs, both in the fifties, but AJ takes over #1 and Edwards slides into the fourth spot. Left Lane: Jason Line Runs 6.591/210.57, Now #4 Right Lane: Greg Anderson Runs 6.586/210.50, Now #2 The final two cars made nice runs, but Line misses the qualifying bonus points for this round and Anderson settled for second place, more than three hundredths behind first-place qualifier Johnson. In Pro Stock, that's an eternity. Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com |
Round 2 Qualifying
Fri, 27 Apr 2012, 19:40 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Session #2 By Larry Sullivan http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif BAYTOWN, Texas - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 25th annual O'Reilly NHRA Spring Nationals presented by Super Start Batteries listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run: Left Lane: V. Gaines Runs 13.442/66.13, Now #20; Best prior run: 7.212/207.75, Was #20 Right Lane: Chris McGaha Runs 6.676/208.20, Now #14; Best prior run: 6.663/207.82, Was #14 6:13 p.m. Weather conditions: air temperature 81 degrees, relative humidity 67 percent, barometer 29.84 inches, adjusted altitude 2,442 feet, track temperature 105 degrees. Larry Morgan is on the bump spot at 6.650. Gaines' car shook and danced on the launch. McGaha made a full pass, failed to improve. Left Lane: Warren Johnson Runs 6.739/208.81, Now #18; Best prior run: 7.038/207.34, Was #19 Right Lane: Dave Connolly Runs 6.577/210.57, Now #2; Best prior run: 6.658/210.28, Was #13 Connolly just missed the first session field, eight thousandths too slow. He picked up the pace with a nice, straight pass, smooth and easy-looking. He moved all the way up to second spot, but we won't know how good that was until we see some more cars make runs. Now Kurt Johnson is on the bump spot at 6.638. Left Lane: Steve Kent Runs 6.662/209.10, Now #14; Best prior run: 6.740/203.37, Was #19 Right Lane: Larry Morgan Runs 6.623/209.33, Now #9; Best prior run: 6.650/208.88, Was #13 Morgan was just bumped from the field. Both drivers picked up the pace in this session, Morgan bumping KJ, Kent still on the outside of the field. Now Jeg Coughlin is on the bump spot at 6.634. Left Lane: Ronnie Humphrey Runs 6.582/210.80, Now #3; Best prior run: 6.693/209.17, Was #18 Right Lane: Kurt Johnson Runs 6.616/209.49, Now #9; Best prior run: 6.638/209.17, Was #13 KJ was just bumped from the field. Two good runs, Humphrey into the top part of the field and KJ now ninth. That bumped Jeg and Ron Krisher. Rickie Jones is now on the bump spot at 6.629. Left Lane: Greg Stanfield Runs 6.627/208.23, Now #12; Best prior run: 6.677/206.95, Was #18 Right Lane: Jeg Coughlin Runs 7.588/138.93, Now #15; Best prior run: 6.634/209.85, Was #14 Coughlin was just bumped from the field. Stanfield gets in the field, on the bump spot, bumping Jones. Coughlin shook early and slowed on the top end, still outside the field. Left Lane: Shane Gray Runs 6.655/208.26, Now #16; Best prior run: 6.668/207.46, Was #18 Right Lane: Rickie Jones Runs 6.622/209.92, Now #11; Best prior run: 6.629/209.56, Was #13 Jones was just bumped. Greg Stanfield is on the bump spot at 6.627. Gray came up short, but Jones improved enough to get back in, bumping Stanfield. Now Larry Morgan is on the bump spot at 6.623 and he has already made his second run.. Left Lane: Ron Krisher Runs 6.602/210.24, Now #9; Best prior run: 6.631/209.69, Was #14 Right Lane: Rodger Brogdon Runs 6.617/209.39, Now #11; Best prior run: 6.616/209.30, Was #10 Krisher is the last driver with a chance to bump into the field. Krisher jumped back into the field, bumping Morgan to end the bumping cycle. Brogdon failed to improve and Krisher moved him down one spot. Left Lane: Mike Edwards Runs 6.579/209.43, Now #3; Best prior run: 6.599/210.37, Was #8 Right Lane: Erica Enders Runs 6.582/210.47, Now #5; Best prior run: 6.598/210.31, Was #7 The remaining cars are already in the field, looking to move up the ladder. Nice side-by-side runs and both move up the ladder. Mike Edwards' incremental times: 60ft-0.980 sec., 330ft-2.754, 660ft-4.232/167.14 mph, 1,000ft-5.506. Erica Enders' incremental times: 60ft-0.988 sec., 330ft-2.760, 660ft-4.237/166.99 mph, 1,000ft-5.510. Left Lane: Vincent Nobile Runs 6.584/210.93, Now #7; Best prior run: 6.586/210.34, Was #7 Right Lane: Jason Line Runs 6.550/211.00, Now #1; Best prior run: 6.591/210.57, Was #8 Line found whatever was missing in round one and he jumped to the top of the list. May not stick, but it was a good run. Vincent Nobile's incremental times: 60ft-0.992 sec., 330ft-2.766, 660ft-4.243/167.34 mph, 1,000ft-5.515. Jason Line's incremental times: 60ft-0.978 sec., 330ft-2.743, 660ft-4.213/167.95 mph, 1,000ft-5.482. Left Lane: Greg Anderson Runs 6.604/210.41, Now #8; Best prior run: 6.586/210.50, Was #8 Right Lane: Allen Johnson Runs 6.546/211.73, Now #1; Best prior run: 6.554/211.93, Was #2 Last pair. Line just knocked AJ off the top spot on the ladder. Johnson takes back the top spot by a few thousandths, Anderson fails to improve and stays eighth. Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com |
Round 3 Qualifying
Sat, 28 Apr 2012, 13:18 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Session #3 By Larry Sullivan http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif BAYTOWN, Texas - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 25th annual O'Reilly NHRA Spring Nationals presented by Super Start Batteries listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run: Left Lane: Jeg Coughlin Runs 6.661/209.56, Now #13; No Prior Run Right Lane: V. Gaines Runs 6.664/209.36, Now #14; No Prior Run 11:51 a.m. Weather conditions: air temperature 82 degrees, relative humidity 65 percent, barometer 29.91 inches, adjusted altitude 2,422 feet, track temperature 115 degrees. Jeg had a bad run in the second session yesterday and missed the 12-car cutoff. Gaines has yet to make a full pass. Both drivers had a lot of tire spin on the launch and they ran almost-identical numbers. It's too early to tell if those numbers will hold up. Jeg Coughlin's incremental times: 60ft-1.030 sec., 330ft-2.820, 660ft-4.304/166.56 mph, 1,000ft-5.583. V. Gaines' incremental times: 60ft-1.035 sec., 330ft-2.823, 660ft-4.308/166.23 mph, 1,000ft-5.588. Left Lane: Chris McGaha Runs 6.650/209.26, Now #13; No Prior Run Right Lane: Warren Johnson Runs 6.674/209.65, Now #16; No Prior Run Again, tire spin on the launch and 60-foot times that start with a one. cGaha had the quickest run so far, so he moves in at 13th, WJ gets temporary possession of the bump spot. Left Lane: Larry Morgan Runs 6.636/208.94, Now #14; No Prior Run Right Lane: Steve Kent Runs 6.617/210.08, Now #12; No Prior Run The times are slowly improving as we work our way up the ladder, Kent quicker than yesterday's 12-car bump time. Now Jeg Coughlin is on the bump spot at 6.661. Left Lane: Rickie Jones Runs 6.628/209.46, Now #13; Best prior run: 6.622/209.92, Was #13 Right Lane: Shane Gray Runs 6.661/208.75, Now #17; No Prior Run Jones gets in nicely, but Gray comes up short on speed, tying Coughlin's bump time. Left Lane: Rodger Brogdon Runs 6.620/209.75, Now #11; Best prior run: 6.616/209.30, Was #11 Right Lane: Greg Stanfield Runs 6.617/208.68, Now #13; No Prior Run Stanfield had great early numbers and easily bumped into the field. That puts Coughlin on the outside and Chris McGaha is now on the bump spot at 6.650. Rodger Brogdon's incremental times: 60ft-1.004 sec., 330ft-2.787, 660ft-4.268/166.95 mph, 1,000ft-5.544. Greg Stanfield's incremental times: 60ft-0.985 sec., 330ft-2.766, 660ft-4.252/166.21 mph, 1,000ft-5.536. Left Lane: Kurt Johnson Runs 13.569/73.04, Now #10; Best prior run: 6.616/209.49, Was #10 Right Lane: Greg Anderson Runs 6.575/211.00, Now #3; Best prior run: 6.586/210.50, Was #8 The bumping is over for this session, so the remaining cars are battling for starting position. Anderson made the best run of the round so far and moved all the way up to third. KJ shook and slowed. Greg Anderson's incremental times: 60ft-0.990 sec., 330ft-2.760, 660ft-4.234/167.61 mph, 1,000ft-5.505. Left Lane: Erica Enders Runs 6.575/210.64, Now #4; Best prior run: 6.582/210.47, Was #7 Right Lane: Ron Krisher Runs 6.608/210.37, Now #9; Best prior run: 6.602/210.24, Was #9 Enders had the best 60 foot time of the round and matched Anderson's WT, but not his speed. Krisher was slightly slower than his best run yesterday, stayed ninth. Left Lane: Dave Connolly Runs 10.686/83.84, Now #6; Best prior run: 6.577/210.57, Was #5 Right Lane: Vincent Nobile Runs 6.575/210.77, Now #4; Best prior run: 6.584/210.93, Was #8 Connolly launched, shook and slowed. Nobile matched Ender and Anderson, took the position from Enders by a tenth of a mph.Vincent Nobile's incremental times: 60ft-0.991 sec., 330ft-2.758, 660ft-4.233/167.68 mph, 1,000ft-5.505. Left Lane: Jason Line Runs 6.554/211.13, Now #2; Best prior run: 6.550/211.00, Was #2 Right Lane: Ronnie Humphrey Runs 6.614/210.41, Now #8; Best prior run: 6.582/210.80, Was #8 Two good runs, Line with the best ET of the round, but no improvement. Humphrey made a good run, but failed to improve. Left Lane: Allen Johnson Runs 6.563/211.93, Now #1; Best prior run: 6.546/211.73, Was #1 Right Lane: Mike Edwards Runs 6.596/209.79, Now #7; Best prior run: 6.579/209.43, Was #7 Last pair. Both cars had a bit of tire spin on the launch and neither driver improved over yesterday's best. Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From: Dragracecentral.com |
Final Qualifying
Sat, 28 Apr 2012, 16:20 PM
http://www.dragracecentral.com/image...00_leftdot.gif Pro Stock Qualifying Notes, Final Session By Larry Sullivan http://www.dragracecentral.com/image...00_leftdot.gif http://www.dragracecentral.com/images/small_print.gif BAYTOWN, Texas - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 25th annual O'Reilly NHRA Spring Nationals presented by Super Start Batteries listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run: Left Lane: Warren Johnson Runs 13.290/66.40, Now #20; Best prior run: 6.674/209.65, Was #20 Right Lane: Jeg Coughlin Runs 14.762/52.06, Now #17; Best prior run: 6.661/209.56, Was #17 2:52 p.m. Weather conditions: air temperature 84 degrees, relative humidity 60 percent, barometer 29.89 inches, adjusted altitude 2,619 feet, track temperature 122 degrees. Chris McGaha is on the bump spot at 6.650. These two have won just about everything, but both are outside the field and this is their last chance. Both cars went into immediate tire shake and both drivers are done for the weekend. Left Lane: V. Gaines Runs 6.643/210.44, Now #16; Best prior run: 6.664/209.36, Was #19 Right Lane: Chris McGaha Runs 6.647/209.23, Now #17; Best prior run: 6.650/209.26, Was #16 Both drivers made good runs, both improved, but Gaines leapfrogged over McGaha and bumped him from the field. V. Gaines' incremental times: 60ft-1.018 sec., 330ft-2.811, 660ft-4.294/166.48 mph, 1,000ft-5.570. Chris McGaha's incremental times: 60ft-1.010 sec., 330ft-2.801, 660ft-4.288/166.35 mph, 1,000ft-5.570. Left Lane: Shane Gray Runs 6.628/209.36, Now #16; Best prior run: 6.661/208.75, Was #19 Right Lane: Larry Morgan Runs 6.615/209.72, Now #10; Best prior run: 6.636/208.94, Was #15 V. Gaines is on the bump spot at 6.643 and has made his final qualifying run. Gray is the last car in the lanes with a chance to bump Gaines. Gray had the first under-one-second sixty-foot time of the session and made a clean, straight run to bump Gaines from the field. Meanwhile, Morgan made his best run of the event and moved up several rungs on the ladder. Shane Gray's incremental times: 60ft-0.996 sec., 330ft-2.779, 660ft-4.266/165.84 mph, 1,000ft-5.550. Larry Morgan's incremental times: 60ft-1.005 sec., 330ft-2.782, 660ft-4.262/166.66 mph, 1,000ft-5.540. Left Lane: Greg Stanfield Runs 6.632/208.81, Now #14; Best prior run: 6.617/208.68, Was #14 Right Lane: Rickie Jones Runs 6.658/208.91, Now #15; Best prior run: 6.622/209.92, Was #15 Stanfield was also under one second for the first sixty feet, but failed to improve. Jones was on a good pace to half track, but ran out of steam on the top half. Left Lane: Steve Kent Runs 6.596/210.24, Now #9; Best prior run: 6.617/210.08, Was #13 Right Lane: Rodger Brogdon Runs 6.665/209.49, Now #13; Best prior run: 6.616/209.30, Was #12 Kent made a strong run to move up, but he stayed in the bottom half. Brogdon did not improve. Left Lane: Ron Krisher Runs 6.593/210.67, Now #9; Best prior run: 6.602/210.24, Was #10 Right Lane: Kurt Johnson Runs 10.652/105.14, Now #12; Best prior run: 6.616/209.49, Was #12 KJ launched into immediate shake. Krisher improved slightly, moved up one spot, and will probably be in the first pair out tomorrow. Left Lane: Ronnie Humphrey Runs 6.601/210.47, Now #8; Best prior run: 6.582/210.80, Was #8 Right Lane: Dave Connolly Runs 6.568/211.00, Now #3; Best prior run: 6.577/210.57, Was #6 The remaining cars are already in the top half of the field. Connolly made the best run of the round so far and moved up to the third spot. Humphrey failed to improve. Left Lane: Mike Edwards Runs 6.596/210.90, Now #7; Best prior run: 6.579/209.43, Was #7 Right Lane: Erica Enders Runs 6.578/210.83, Now #6; Best prior run: 6.575/210.64, Was #6 Two good runs, neither driver improved. Left Lane: Vincent Nobile Runs 6.564/211.36, Now #3; Best prior run: 6.575/210.77, Was #5 Right Lane: Jason Line Runs 6.556/211.43, Now #2; Best prior run: 6.550/211.00, Was #2 Line runs the quickest ET of the round so far. His final three runs were 6.55something, his car consistently quick. Nobile made his best run of the weekend, moving onto the "hot potato" third spot. with the second-quickest run so far in this session Left Lane: Greg Anderson Runs 6.597/211.49, Now #5; Best prior run: 6.575/211.00, Was #5 Right Lane: Allen Johnson Runs 6.560/211.66, Now #1; Best prior run: 6.546/211.73, Was #1 Last two cars. Anderson had some tire spin on the launch and failed to improve. AJ made a good pass, second-quickest of the session, also failed to improve. Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From : DragRaceCentral.com |
Summary of Eliminations
Sun, 29 Apr 2012, 19:47 PM
http://www.dragracecentral.com/image...00_leftdot.gif Summary of Eliminations in Pro Stock http://www.dragracecentral.com/images/small_print.gif BAYTOWN, Texas - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 25th annual O'Reilly NHRA Spring Nationals presented by Super Start Batteries: Round 1: Ronnie Humphrey, Jacksonville NC, '09 GXP, Left lane, (0.066) 6.607 210.54 def. Ron Krisher, Warren OH, '09 GXP, (0.078) 6.608209.65 Mike Edwards, Coweta OK, '09 GXP, Left lane, (0.054) 6.580 209.88 def. Steve Kent, Lottie LA, '09 GXP, (0.068) 6.611 209.85 Larry Morgan, Newark OH, '12 Mustang, Right lane, (0.040) 6.655 208.55 def. Erica Enders, New Orleans LA, '10 Cobalt, (0.060) 6.723208.84 Dave Connolly, Elyria OH, '10 Cobalt, Left lane, (0.053) 6.569 211.13 def. Rodger Brogdon, Tomball TX, '09 GXP, (0.055) 6.628 208.94 Vincent Nobile, Dix Hills NY, '12 Avenger, Left lane, (0.020) 6.581 210.73 def. Greg Stanfield, Bossier City LA, '12 Camaro, (0.024)6.637 208.17 Allen Johnson, Greeneville TN, '12 Avenger, Left lane, (0.069) 6.564 211.20 def. Shane Gray, Denver NC, '09 GXP, (0.042) 6.644208.20 Jason Line, Troutman NC, '09 GXP, Left lane, (0.036) 6.571 210.08 def. Rickie Jones, Galesburg IL, '09 GXP, (0.012) 6.637 209.10 Greg Anderson, Mooresville NC, '09 GXP, Left lane, (0.066) 6.605 209.79 def. Kurt Johnson, Sugar Hill GA, '09 GXP, (0.049) 6.631209.39 Round 2: V Nobile, Left lane, (0.027) 15.277 55.65 def. L Morgan, (-0.045 foul) 6.651 209.01 M Edwards, Left lane, (0.030) 6.603 209.75 def. J Line, (0.050) 6.591 210.50 D Connolly, Right lane, (0.019) 6.596 210.11 def. G Anderson, (0.037) 6.611 210.05 A Johnson, Left lane, (0.033) 6.595 211.46 def. R Humphrey, (0.102) 6.603 210.41 Round 3: V Nobile, Right lane, (0.017) 6.622 209.33 def. M Edwards, (0.078) 6.644 209.79 D Connolly, Left lane, (0.017) 6.584 210.34 def. A Johnson, (0.038) 6.580 211.56 Round 4: V Nobile, Right lane, (0.009) 6.595 210.14 def. D Connolly, (0.011) 6.604 210.41 Low ET: Allen Johnson 6.546 seconds Top Speed: Allen Johnson 211.93 MPH Timing data courtesy of CompuLink http://www.dragracecentral.com/image...t_endstory.gif From DragRaceCentral.com |
