NHRA Mopar Mile High Nats Denver
Fri, 22 Jul 2011, 09:48 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
MORRISON, Colo. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 32nd annual Mopar Mile-High NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Kurt Johnson Runs 7.117/194.49, Now #14; Best prior run: 7.187/193.32, Was #13
Right Lane: Larry Morgan Runs 7.109/192.82, Now #12; No Prior Run
Weather conditions: air temperature 89 degrees, relative humidity 25 percent, barometer 24.09 inches, adjusted altitude 9,820 feet, track temperature 84 degrees.
Johnson with his quickest pass, but won't get in the show. Morgan with his quickest pass of the day and gets into the show for now. Larry Morgan's incremental times: 60ft-1.020 sec., 330ft-2.941, 660ft-4.550/153.49 mph, 1,000ft-5.939.
Left Lane: Erica Enders Runs 7.048/196.02, Now #6; Best prior run: 7.111/194.69, Was #13
Right Lane: Steve Kalkowski Runs 7.739/188.15, Now #15; Best prior run: 11.402/77.64, Was #16
Kalkowski improves, but not enough to get in the show. Ender with a great looking pass to get in the show. Erica Enders' incremental times: 60ft-1.017 sec., 330ft-2.931, 660ft-4.525/155.24 mph, 1,000ft-5.895.
Left Lane: Ronnie Humphrey Runs 7.076/195.22, Now #11; Best prior run: 7.103/194.69, Was #12
Right Lane: Allen Johnson Runs 6.992/196.96, Now #1; Best prior run: 9.249/103.28, Was #16
Humphrey improves and gets off the bump spot. Ronnie Humphrey's incremental times: 60ft-1.039 sec., 330ft-2.953, 660ft-4.548/155.06 mph, 1,000ft-5.920. Johnson launched hard and keep it hooked up to go to the number one spot. Allen Johnson's incremental times: 60ft-1.011 sec., 330ft-2.899, 660ft-4.483/156.03 mph, 1,000ft-5.846.
Left Lane: Jason Line Runs 7.037/195.53, Now #5; Best prior run: 7.063/195.14, Was #9
Right Lane: Ron Krisher Runs 7.027/196.13, Now #4; Best prior run: 7.089/195.68, Was #13
Krisher with a great pass to get in the show all the way up to the number four spot. Ron Krisher's incremental times: 60ft-1.018 sec., 330ft-2.916, 660ft-4.507/155.42 mph, 1,000ft-5.876. Line gets into the top half of the show...Jason Line's incremental times: 60ft-1.019 sec., 330ft-2.921, 660ft-4.512/155.35 mph, 1,000ft-5.881.
Left Lane: Greg Stanfield Runs 7.034/195.31, Now #5; Best prior run: 7.047/194.91, Was #8
Right Lane: Warren Johnson Runs 7.046/195.22, Now #9; Best prior run: 7.085/194.24, Was #13
Stanfield with a real nice pass to get in the top half of the show. Johnson gets into the show. Greg Stanfield's incremental times: 60ft-1.013 sec., 330ft-2.910, 660ft-4.503/155.10 mph, 1,000ft-5.877.
Warren Johnson's incremental times: 60ft-1.009 sec., 330ft-2.915, 660ft-4.514/154.76 mph, 1,000ft-5.889.
Left Lane: Shane Gray Runs 7.038/195.62, Now #8; Best prior run: 7.045/195.08, Was #8
Right Lane: Greg Anderson Runs 7.038/196.27, Now #7; Best prior run: 7.074/195.82, Was #12
These two run identical E.T.s and Anderson gets the higher spot based on mph. Shane Gray's incremental times: 60ft-1.011 sec., 330ft-2.910, 660ft-4.507/154.94 mph, 1,000ft-5.882.
Greg Anderson's incremental times: 60ft-1.035 sec., 330ft-2.932, 660ft-4.521/155.88 mph, 1,000ft-5.888.
Left Lane: V. Gaines Runs 7.011/195.25, Now #2; Best prior run: 7.024/196.19, Was #3
Right Lane: Rodger Brogdon Runs 7.039/195.45, Now #9; Best prior run: 7.049/194.97, Was #12
Brogdon gets off the bump with a good pass. Rodger Brogdon's incremental times: 60ft-1.014 sec., 330ft-2.921, 660ft-4.514/154.85 mph, 1,000ft-5.885. Gaines launched hard and was straight down the groove to go to the number two spot. V. Gaines' incremental times: 60ft-1.009 sec., 330ft-2.902, 660ft-4.490/155.31 mph, 1,000ft-5.859.
Left Lane: Mike Edwards Runs 6.989/196.50, Now #1; Best prior run: 7.018/196.24, Was #3
Right Lane: Vincent Nobile Runs 7.120/195.42, Now #10; Best prior run: 7.040/196.16, Was #10
No help here for Nobile, and he will stay in the number 10 spot. Edwards with a great pass to get the number one spot back...Mike Edwards' incremental times: 60ft-1.004 sec., 330ft-2.893, 660ft-4.477/155.96 mph, 1,000ft-5.841.
Timing data courtesy of CompuLink
From DragRaceCentral.com
By Rick Green
That is so true.... When you are running at almost 10,000 ft the air is so thin that you just can't make the HP it takes to run the quick numbers.. I have been told at that alt it will take app 20% out of a naturally aspirated engine... The turbos can make their own air so they are not effected as much at the others...
Round 3 Qualifying
Sat, 23 Jul 2011, 04:22 PM
Pro Stock Qualifying Notes, Session #3
By Rick Green
MORRISON, Colo. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 32nd annual Mopar Mile-High NHRA Nationals
Left Lane: Kurt Johnson Runs 7.049/195.36, Now #13; No Prior Run
Right Lane: Steve Kalkowski Runs 7.645/188.25, Now #14; No Prior Run
Weather conditions: air temperature 92 degrees, relative humidity 24 percent, barometer 24.24 inches, adjusted altitude 9,782 feet, track temperature 112 degrees.
Kalkowski with his quickest pass of the weekend and he will get a start as there are only 16 cars here. Johnson with his quickest pass of the weekend...Kurt Johnson's incremental times: 60ft-1.012 sec., 330ft-2.922, 660ft-4.519/154.74 mph, 1,000ft-5.893.
Left Lane: Ronnie Humphrey Runs 19.531/43.99, Now #15; No Prior Run
Right Lane: Vincent Nobile Runs 7.006/196.36, Now #3; Best prior run: 7.040/196.16, Was #10
Humphrey with problems as soon as he let the clutch out. Nobile launched hard and keep it hooked up to go to the number three spot. Vincent Nobile's incremental times: 60ft-1.022 sec., 330ft-2.910, 660ft-4.495/155.96 mph, 1,000ft-5.858.
Left Lane: Erica Enders Runs 7.069/195.51, Now #12; Best prior run: 7.048/196.02, Was #12
Right Lane: Larry Morgan Runs 7.094/195.99, Now #14; No Prior Run
Morgan with his quickest pass of the weekend...Larry Morgan's incremental times: 60ft-1.065 sec., 330ft-2.976, 660ft-4.571/154.99 mph, 1,000ft-5.941. Enders slows from her time yesterday.
Left Lane: Shane Gray Runs 7.061/195.42, Now #9; Best prior run: 7.038/195.62, Was #9
Right Lane: Warren Johnson Runs 7.073/194.91, Now #11; Best prior run: 7.046/195.22, Was #11
Both drivers slow from yesterday...Shane Gray's incremental times: 60ft-1.031 sec., 330ft-2.937, 660ft-4.532/155.06 mph, 1,000ft-5.905.
Warren Johnson's incremental times: 60ft-1.029 sec., 330ft-2.938, 660ft-4.537/154.69 mph, 1,000ft-5.914.
Left Lane: Jason Line Runs 7.008/195.87, Now #4; Best prior run: 7.037/195.53, Was #7
Right Lane: Rodger Brogdon No Time, Now #10; Best prior run: 7.039/195.45, Was #10
Brogdon with problems as soon as he let the clutch out and came to a stop on the track...Line with a nice pass the second quickest of this round. Jason Line's incremental times: 60ft-1.021 sec., 330ft-2.908, 660ft-4.491/155.81 mph, 1,000ft-5.856.
Left Lane: Greg Stanfield Runs 7.033/195.03, Now #8; Best prior run: 7.034/195.31, Was #7
Right Lane: Greg Anderson Runs 7.014/195.90, Now #6; Best prior run: 7.038/196.27, Was #8
Anderson with his quickest pass of the weekend and the third quickest pass of the session. Greg Anderson's incremental times: 60ft-1.022 sec., 330ft-2.915, 660ft-4.499/156.01 mph, 1,000ft-5.864. Stanfield with his quickest pass of the weekend, but still gest bumped back one spot. Greg Stanfield's incremental times: 60ft-1.012 sec., 330ft-2.908, 660ft-4.501/154.88 mph, 1,000ft-5.875.
Left Lane: V. Gaines Runs 7.004 /197.02, Now #3; Best prior run: 7.011/195.25, Was #5
Right Lane: Ron Krisher Runs 7.046/196.90, Now #7; Best prior run: 7.027/196.13, Was #7
Gaines with his quickest pass of the weekend and moves up to the third spot on the ladder. Gaines with the quickest pass of the session. V. Gaines' incremental times: 60ft-1.030 sec., 330ft-2.918, 660ft-4.498/156.46 mph, 1,000ft-5.859. Krisher slows from his pass yesterday.
Left Lane: Mike Edwards Runs 6.988/196.82, Now #2; Best prior run: 6.989/196.50, Was #1
Right Lane: Allen Johnson Runs 6.983/197.13, Now #1; Best prior run: 6.992/196.96, Was #2
Johnson with his quickest pass of the weekend to go to the number one spot. Allen Johnson's incremental times: 60ft-1.011 sec., 330ft-2.896, 660ft-4.477/156.30 mph, 1,000ft-5.838. Edwards with his quickest pass of the weekend and he is now second. Mike Edwards' incremental times: 60ft-1.006 sec., 330ft-2.895, 660ft-4.477/156.26 mph, 1,000ft-5.840.
By Rick Green
Final Qualifying
Sat, 23 Jul 2011, 06:56 PM
Pro Stock Qualifying Notes, Final Session
By Rick Green
MORRISON, Colo. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 32nd annual Mopar Mile-High NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Steve Kalkowski Runs 7.252/189.36, Now #16; Best prior run: 7.645/188.25, Was #15
Right Lane: Ronnie Humphrey Runs 7.048/195.73, Now #13; Best prior run: 19.531/43.99, Was #16
Weather conditions: air temperature 95 degrees, relative humidity 18 percent, barometer 24.23 inches, adjusted altitude 9,932 feet, track temperature 112 degrees.
Kalkowski with his quickest pass of the weekend. Steve Kalkowski's incremental times: 60ft-1.034 sec., 330ft-2.997, 660ft-4.642/150.23 mph, 1,000ft-6.058. Humphrey with his quickest pass of the weekend to move up the ladder.
Left Lane: Larry Morgan Runs 7.012/196.13, Now #6; Best prior run: 7.094/195.99, Was #15
Right Lane: Kurt Johnson Runs 7.042/195.25, Now #12; Best prior run: 7.049/195.36, Was #14
Johnson with his quickest pass of the weekend and moves up the ladder. Kurt Johnson's incremental times: 60ft-1.013 sec., 330ft-2.914, 660ft-4.512/154.76 mph, 1,000ft-5.886. Morgan with a great pass to get into the top half of the show. Larry Morgan's incremental times
Left Lane: Warren Johnson Runs 12.646/77.74, Now #14; Best prior run: 7.046/195.22, Was #13
Right Lane: Erica Enders Runs 7.008/196.27, Now #5; Best prior run: 7.048/196.02, Was #14
WJ with problems as soon as he lets the clutch out. Enders with a really nice pass, her quickest of the weekend to get into the top half of the show. Erica Enders' incremental times: 60ft-1.005 sec., 330ft-2.901, 660ft-4.489/155.47 mph, 1,000ft-5.857. The quickest of the round so far.
Left Lane: Rodger Brogdon Runs 7.016/195.87, Now #9; Best prior run: 7.039/195.45, Was #12
Right Lane: Shane Gray Runs 7.054/195.03, Now #12; Best prior run: 7.038/195.62, Was #11
No help here for Gray. Brogdon with his quickest pass of the weekend. Rodger Brogdon's incremental times: 60ft-1.012 sec., 330ft-2.907, 660ft-4.495/155.42 mph, 1,000ft-5.863.
Left Lane: Ron Krisher Runs 7.064/195.76, Now #10; Best prior run: 7.027/196.13, Was #10
Right Lane: Greg Stanfield Runs 7.030/195.48, Now #11; Best prior run: 7.033/195.03, Was #11
No help here for Krisher...Stanfield with his quickest pass of the weekend, but will stay in the number 11 spot. Greg Stanfield's incremental times: 60ft-1.014 sec., 330ft-2.910, 660ft-4.501/155.10 mph, 1,000ft-5.874.
Left Lane: Greg Anderson Runs 7.040/192.11, Now #8; Best prior run: 7.014/195.90, Was #8
Right Lane: Jason Line Runs 7.010/195.73, Now #6; Best prior run: 7.008/195.87, Was #6
Anderson with a lot of smoke as he crossed the finish line. No help here for Line.
Left Lane: Vincent Nobile Runs 6.996/196.39, Now #4; Best prior run: 7.006/196.36, Was #4
Right Lane: V. Gaines Runs 6.982/196.76, Now #1; Best prior run: 7.004 /197.02, Was #3
This was great drag race...Gaines goes to the number one spot with his quickest pass of the weekend. V. Gaines' incremental times: 60ft-1.011 sec., 330ft-2.895, 660ft-4.475/156.19 mph, 1,000ft-5.836. Nobile with his quickest pass of the weekend, but will stay in the number four spot. Vincent Nobile's incremental times: 60ft-1.015 sec., 330ft-2.902, 660ft-4.485/156.08 mph, 1,000ft-5.848.
Left Lane: Allen Johnson Runs 6.978/197.65, Now #1; Best prior run: 6.983/197.13, Was #2
Right Lane: Mike Edwards Runs 6.986/197.19, Now #3; Best prior run: 6.988/196.82, Was #3
Edwards with his quickest pass of the weekend, but will stay in the number three spot. Mike Edwards' incremental times: 60ft-1.005 sec., 330ft-2.895, 660ft-4.477/156.12 mph, 1,000ft-5.840. Johnson takes back the number one spot with a great pass...Allen Johnson's incremental times: 60ft-1.008 sec., 330ft-2.893, 660ft-4.474/156.44 mph, 1,000ft-5.835.
By Rick Green
Round 1 Eliminations
Sunday
Results for Elimination Round 1
MORRISON, Colo. - SUMMIT FastNews - Results of round 1 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 32nd annual Mopar Mile-High NHRA Nationals:
W/L Driver R-Time E-Time Speed
(W) Greg Anderson (Summit Racing Equipment GXP) 0.016 7.021 195.73 (L) Rodger Brogdon (The Edge GXP) 0.060 7.044 195.76
Weather conditions: air temperature 85 degrees, relative humidity 32 percent, barometer 24.36 inches, adjusted altitude 9,254 feet, track temperature 108 degrees.Anderson is 9 - 0 against Brogdon in prior events. Anderson won here in 2004 and 2008. Anderson with the starting line advantage and spun the tire, but never trailed for the win.
(W) Larry Morgan (Lucas Oil/Summit Mustang) 0.038 7.012 196.62
(L) Ron Krisher (Valvoline GXP) 0.054 7.001 196.50
Krisher is 6 - 4 against Morgan in prior events. This is the 24th time Morgan has raced on the mountain and the 10th time he has qualified in the top half of the field. He won here in 1990. Krisher was the runner-up here in 2007. Morgan with the starting line advantage and the power to hold on for the hole shot win. Larry Morgan's MOV: 0.0059 seconds (approximately 20 inches).
(W) V. Gaines (Kendall Oil Avenger) 0.052 9.000 96.24
(L) Ronnie Humphrey (Genuine Hot Rod Hardware G -0.070(R) 7.074 191.16 Gaines and Humphrey have each won 1 times against the other in prior events. This is Gaines best starting position this year. Humphrey went red and gave Gaines the freebie and then Gaines has problems and pushes in the clutch. Gaines with the win. Gaines will give up lane choice to Morgan in the next round.
(W) Erica Enders (ZaZa Energy Cobalt) 0.012 6.978 196.85
(L) Shane Gray (Service Central GXP) 0.032 7.376 150.00
Gray is 1 - 0 against Enders in prior events. Enders with the starting line advantage and then runs her quickest pass of the weekend for the win. This pass ties Johnson for quickest pass of the weekend....Erica Enders' incremental times: 60ft-1.001 sec., 330ft-2.884, 660ft-4.466/156.10 mph, 1,000ft-5.830.
(W) Kurt Johnson (Wiseco Performance Products G 0.010 7.038 195.42
(L) Vincent Nobile (Mountainview Tire Avenger) -0.001(R) 6.992 196.99
Nobile is 1 - 0 against Johnson in prior events. Nobile ties his best starting position this year. Nobile is just a tick too quick and turns on the red light giving Johnson the freebie. Johnson with his quickest pass of the weekend for the win. He will give up lane choice to Enders in the next round.
(W) Allen Johnson (Mopar/J & J Racing Avenger) 0.073 6.962 198.06
(L) Steve Kalkowski (Steve's Body & Paint GTO) 0.063 7.239 189.23
This is the first time Johnson and Kalkowski have faced each other in eliminations. Johnson has won this event the last two years and also in 2007, plus a runner-up in 2002 and 2008. This is the 58th different driver Johnson has faced. Kalkowski is making his first start in only his fifth race. Kalkowski with a slight starting line advantage and then made a move toward the centerline. Johnson had the starting line difference made up by the time they went by the Christmas tree and then runs low E.T. and top speed of the event for the win. Johnson will have lane choice over Anderson in the next round.
(W) Mike Edwards (Penhall/K&N/Interstae GXP) 0.085 6.974 196.19
(L) Warren Johnson (K&N Filters GXP) 0.122 7.035 195.76
Edwards is 24 - 16 against Johnson in prior events. Edwards with the starting line advantage and then second quickest pass of the round for the win light. Johnson with his quickest pass of the weekend in the losing effort.
(W) Jason Line (Summit Racing Equipment GXP) 0.031 6.991 196.30
(L) Greg Stanfield (Nitrofish GXP) 0.030 7.018 196.13
Line is 19 - 14 against Stanfield in prior events. They leave together and then it is all Line on his birthday for the win. Line with his quickest pass of the weekend, but will give up lane choice to Edwards in the next round. Stanfield with his quickest pass of the weekend in the losing effort.
From NHRA.com
From NHRA.com
Summary of Eliminations
Sun, 24 Jul 2011, 07:44 PM
Summary of Eliminations in Pro Stock
MORRISON, Colo. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 32nd annual Mopar Mile-High NHRA Nationals:
Round 1:
Greg Anderson, Mooresville NC, '09 GXP, Left lane, (0.016) 7.021 195.73 def. Rodger Brogdon,Tomball TX, '09 GXP, (0.060) 7.044 195.76
Larry Morgan, Newark OH, '11 Mustang, Left lane, (0.038) 7.012 196.62 def. Ron Krisher, Warren OH,'09 GXP, (0.054) 7.001 196.50
V. Gaines, Lakewood CO, '11 Avenger, Left lane, (0.052) 9.000 96.24 def. Ronnie Humphrey,Jacksonville NC, '09 GXP, (-0.070 foul) 7.074 191.16
Erica Enders, New Orleans LA, '10 Cobalt, Left lane, (0.012) 6.978 196.85 def. Shane Gray, DenverNC, '09 GXP, (0.032) 7.376 150.00
Kurt Johnson, Sugar Hill GA, '09 GXP, Right lane, (0.010) 7.038 195.42 def. Vincent Nobile, DixHills NY, '11 Avenger, (-0.001 foul) 6.992 196.99
Allen Johnson, Greeneville TN, '11 Avenger, Left lane, (0.073) 6.962 198.06 def. Steve Kalkowski,Ogallala NE, '07 GTO, (0.063) 7.239 189.23
Mike Edwards, Coweta OK, '09 GXP, Left lane, (0.085) 6.974 196.19 def. Warren Johnson, Sugar HillGA, '09 GXP, (0.122) 7.035 195.76
Jason Line, Mooresville NC, '09 GXP, Left lane, (0.031) 6.991 196.30 def. Greg Stanfield, BossierCity LA, '09 GXP, (0.030) 7.018 196.13
Round 2:
L Morgan, Left lane, (0.010) 7.058 195.08 def. V Gaines, (0.182) 6.975 197.42
K Johnson, Right lane, (0.017) 7.032 195.59 def. E Enders, (-0.013 foul) 6.988 196.64
M Edwards, Left lane, (0.015) 6.966 197.31 def. J Line, (0.017) 6.984 196.16
A Johnson, Left lane, (0.008) 6.955 198.15 def. G Anderson, (0.033) 6.986 195.70
Round 3:
M Edwards, Left lane, (0.017) 6.974 197.08 def. L Morgan, (0.040) 7.048 195.96
A Johnson, Left lane, (0.023) 6.988 197.48 def. K Johnson, (0.026) 7.044 195.31
Round 4:
M Edwards, Left lane, (0.027) 6.970 197.65 def. A Johnson, (-0.009 foul) 7.015 197.62
Low ET: Allen Johnson 6.955 seconds
Top Speed: Allen Johnson 198.15 MPH
Round 1:
Round 2:
Round 3:
Round 4:
