NHRA Thunder Valley Nationals Bristol
Old 06-17-2011, 03:07 PM
Fri, 17 Jun 2011, 05:32 PM
Pro Stock Qualifying Notes, Session #1
By Rick Green
BRISTOL, Tenn. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 11th annual Ford NHRA Thunder Valley Nationals presented by Tri-Cities Area Ford Dealers listing lane, driver name, elapsed time, top speed, and position in order following run:
Right Lane: John Gaydosh Jr Runs 6.984/198.38, Now #1
Gaydosh was straight down the groove...
Left Lane: Steve Spiess Runs 6.844/201.94, Now #1
Right Lane: Frank Gugliotta Runs 6.852/202.00, Now #2
These two were side by side...
Left Lane: Robert Patrick Runs 6.822/202.97, Now #2
Right Lane: Bob Benza Runs 6.779/203.25, Now #1
A couple good passes...
Left Lane: Buddy Perkinson Runs 6.793/203.55, Now #3
Right Lane: Steve Kent Runs 6.752/205.19, Now #1
Kent goes to the top of the list...Steve Kent's incremental times: 60ft-1.016 sec., 330ft-2.836, 660ft-4.348/163.04 mph, 1,000ft-5.653. Perkinson is out for the first time since Atlanta...Buddy Perkinson's incremental times: 60ft-1.025 sec., 330ft-2.848, 660ft-4.370/161.50 mph, 1,000ft-5.685.
Left Lane: Richard Freeman Runs 6.760/205.04, Now #2
Right Lane: Warren Johnson Runs 6.787/205.04, Now #4
Johnson with a little wiggle right off the starting line...Freeman with a nice pass to go to the number two spot. Richard Freeman's incremental times: 60ft-1.008 sec., 330ft-2.837, 660ft-4.353/162.43 mph, 1,000ft-5.660.
Left Lane: Kurt Johnson Runs 13.842/67.28, Now #11
Right Lane: Larry Morgan Runs 6.792/203.58, Now #5
Johnson with a new car this weekend.Weather conditions: air temperature 83 degrees, relative humidity 44 percent, barometer 28.38 inches, adjusted altitude 4,055 feet, track temperature 121 degrees.
Johnson made a quick move toward the centerline and clicked it off. Morgan spun the tires right off the starting line.
Left Lane: V. Gaines Runs 6.751/205.22, Now #2
Right Lane: Ronnie Humphrey Runs 6.733/205.91, Now #1
These two go to the top of the list...Humphrey with the quickest 60-foot time and he parlays that into the No. 1 spot. Ronnie Humphrey's incremental times: 60ft-1.024 sec., 330ft-2.835, 660ft-4.340/163.63 mph, 1,000ft-5.638.
V. Gaines' incremental times: 60ft-1.014 sec., 330ft-2.837, 660ft-4.351/162.72 mph, 1,000ft-5.654.
Left Lane: Ron Krisher No Time, Now #15
Right Lane: Shane Gray Runs 6.724/205.47, Now #1
Krisher was timed out and will not get a time. Gray with a great pass and goes to the number one spot. Shane Gray's incremental times: 60ft-1.001 sec., 330ft-2.815, 660ft-4.325/163.47 mph, 1,000ft-5.628.
Left Lane: Erica Enders Runs 6.700/206.04, Now #1
Right Lane: Allen Johnson Runs 6.709/206.70, Now #2
This was a great drag race with these two going to the top of the list. Enders with the quickest pass and Johnson with the fastest. Erica Enders' incremental times: 60ft-0.994 sec., 330ft-2.799, 660ft-4.306/163.28 mph, 1,000ft-5.605.
Allen Johnson's incremental times: 60ft-1.005 sec., 330ft-2.813, 660ft-4.320/163.41 mph, 1,000ft-5.617.
Left Lane: Rodger Brogdon Runs 6.696/206.45, Now #1
Right Lane: Vincent Nobile Runs 6.730/205.82, Now #5
Brogdon with great pass to go to the number one spot...Rodger Brogdon's incremental times: 60ft-1.002 sec., 330ft-2.805, 660ft-4.308/163.89 mph, 1,000ft-5.604. Nobile with a real nice pass to get into the top half of the show. Vincent Nobile's incremental times: 60ft-1.013 sec., 330ft-2.824, 660ft-4.333/163.37 mph, 1,000ft-5.634.
Left Lane: Mike Edwards Runs 6.702/206.04, Now #3
Right Lane: Greg Anderson Runs 6.725/205.19, Now #6
Edwards with the quickest 60-foot of the session and goes to the number three spot. Mike Edwards' incremental times: 60ft-0.993 sec., 330ft-2.805, 660ft-4.311/163.55 mph, 1,000ft-5.609. Anderson gets into the top half of the show...Greg Anderson's incremental times: 60ft-1.004 sec., 330ft-2.814, 660ft-4.322/163.14 mph, 1,000ft-5.626.
Left Lane: Greg Stanfield Runs 6.744/205.29, Now #10
Right Lane: Jason Line Runs 6.717/205.66, Now #5
Line is straight down the groove to go to the number five spot...Jason Line's incremental times: 60ft-1.002 sec., 330ft-2.817, 660ft-4.323/163.85 mph, 1,000ft-5.622. Stanfield gets into the show and bumps out Freeman...Greg Stanfield's incremental times: 60ft-1.013 sec., 330ft-2.827, 660ft-4.340/163.02 mph, 1,000ft-5.644.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old 06-18-2011, 04:28 AM
Round 2 Qualifying
Fri, 17 Jun 2011, 09:18 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
BRISTOL, Tenn. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 11th annual Ford NHRA Thunder Valley Nationals presented by Tri-Cities Area Ford Dealers listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: John Gaydosh Jr Runs 6.990/198.00, Now #21; Best prior run: 6.984/198.38, Was #21
No help here for Gaydosh...
Left Lane: Frank Gugliotta Runs 12.755/65.50, Now #21; Best prior run: 6.852/202.00, Was #20
Right Lane: Ron Krisher Runs 6.752/204.48, Now #13; No Prior Run
Gugliotta shook and shut it off. Krisher matches Kent's E.T., but Kent gets the position based on his faster mph. Ron Krisher's incremental times: 60ft-1.000 sec., 330ft-2.821, 660ft-4.341/162.16 mph, 1,000ft-5.651.
Left Lane: Larry Morgan Runs 7.742/131.34, Now #17; Best prior run: 6.792/203.58, Was #17
Right Lane: Kurt Johnson Runs 7.101/159.57, Now #23; Best prior run: 13.842/67.28, Was #23
Morgan and Johnson with problems and they both push in the clutches...
Left Lane: Warren Johnson Runs 6.739/204.29, Now #10; Best prior run: 6.787/205.04, Was #16
Right Lane: Steve Spiess Runs 6.831/201.10, Now #20; Best prior run: 6.844/201.94, Was #20
Johnson with a real nice pass to get in the show...Warren Johnson's incremental times: 60ft-1.002 sec., 330ft-2.816, 660ft-4.332/162.31 mph, 1,000ft-5.638. Spies improves, but won't move up the ladder.
Left Lane: Bob Benza Runs 6.777/202.42, Now #17; Best prior run: 6.779/203.25, Was #16
Right Lane: Robert Patrick Runs 6.773/202.55, Now #16; Best prior run: 6.822/202.97, Was #19
Both drivers improve, but neither enough to get in the show...
Left Lane: Steve Kent Runs 6.765/203.46, Now #13; Best prior run: 6.752/205.19, Was #13
Right Lane: Buddy Perkinson Runs 6.788/203.46, Now #18; Best prior run: 6.793/203.55, Was #19
No help here for Kent...Perkinson improves and moves up the ladder one spot. Buddy Perkinson's incremental times: 60ft-1.021 sec., 330ft-2.848, 660ft-4.368/162.04 mph, 1,000ft-5.681.
Left Lane: Ronnie Humphrey Runs 7.509/138.10, Now #9; Best prior run: 6.733/205.91, Was #9
Right Lane: Richard Freeman Runs 6.741/204.76, Now #11; Best prior run: 6.760/205.04, Was #15
Humphrey with problems and pushes in the clutch early...Freeman with a great looking pass to get in the show...Richard Freeman's incremental times: 60ft-1.004 sec., 330ft-2.814, 660ft-4.329/162.22 mph, 1,000ft-5.639.
Left Lane: Vincent Nobile Runs 6.725/205.44, Now #7; Best prior run: 6.730/205.82, Was #8
Right Lane: V. Gaines Runs 6.736/204.45, Now #10; Best prior run: 6.751/205.22, Was #13
Nobile with the quickest pass of the round and moves up the ladder one spot. Vincent Nobile's incremental times: 60ft-0.998 sec., 330ft-2.811, 660ft-4.325/162.78 mph, 1,000ft-5.627. Gaines gets back in the show with a nice pass. V. Gaines' incremental times: 60ft-1.003 sec., 330ft-2.814, 660ft-4.328/162.55 mph, 1,000ft-5.636.
Left Lane: Greg Anderson Runs 6.718/205.07, Now #6; Best prior run: 6.725/205.19, Was #8
Right Lane: Greg Stanfield Runs 6.729/204.35, Now #9; Best prior run: 6.744/205.29, Was #13
Anderson with the quickest pass of the round to move into the top half of the show. Greg Anderson's incremental times: 60ft-0.997 sec., 330ft-2.810, 660ft-4.320/163.04 mph, 1,000ft-5.621. Stanfield with his quickest pass of the weekend to get back in the show. Greg Stanfield's incremental times: 60ft-1.002 sec., 330ft-2.809, 660ft-4.320/163.02 mph, 1,000ft-5.627.
Left Lane: Shane Gray Runs 6.723/204.79, Now #7; Best prior run: 6.724/205.47, Was #7
Right Lane: Mike Edwards Runs 6.679/205.94, Now #1; Best prior run: 6.702/206.04, Was #3
Gray improves, but will stay in the number seven spot. Edwards with the quickest 60-foot time and goes to the number one spot. Mike Edwards' incremental times: 60ft-0.985 sec., 330ft-2.786, 660ft-4.289/163.87 mph, 1,000ft-5.586.
Left Lane: Jason Line Runs 6.733/204.76, Now #5; Best prior run: 6.717/205.66, Was #5
Right Lane: Erica Enders Runs 6.704/205.54, Now #3; Best prior run: 6.700/206.04, Was #3
Weather conditions: air temperature 77 degrees, relative humidity 61 percent, barometer 28.40 inches, adjusted altitude 3,719 feet, track temperature 94 degrees.
Line slows from his earlier pass today. Enders almost matches her time from earlier today. Erica Enders' incremental times: 60ft-0.993 sec., 330ft-2.800, 660ft-4.307/163.33 mph, 1,000ft-5.608.
Left Lane: Allen Johnson Runs 6.696/205.98, Now #3; Best prior run: 6.709/206.70, Was #4
Right Lane: Rodger Brogdon Runs 6.723/204.98, Now #2; Best prior run: 6.696/206.45, Was #2
Johnson with the second quickest pass of this round and he will tie Brogdon's E.T. but will give up the position to Brogdon. Allen Johnson's incremental times: 60ft-0.985 sec., 330ft-2.791, 660ft-4.300/163.28 mph, 1,000ft-5.601. Brogdon with another good looking pass...Rodger Brogdon's incremental times: 60ft-1.002 sec., 330ft-2.809, 660ft-4.320/162.82 mph, 1,000ft-5.624.
Old 06-18-2011, 03:24 PM
Round 3 Qualifying
Sat, 18 Jun 2011, 12:06 PM
Pro Stock Qualifying Notes, Session #3
By Rick Green
BRISTOL, Tenn. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 11th annual Ford NHRA Thunder Valley Nationals presented by Tri-Cities Area Ford Dealers listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Right Lane: Frank Gugliotta Runs 16.568/46.01, Now #13; No Prior Run
Weather conditions: air temperature 78 degrees, relative humidity 62 percent, barometer 38.67 inches, adjusted altitude 28 feet, track temperature 108 degrees.
Gugliotta with a lot of tire shake right off the starting line and clicked it off.
Left Lane: Kurt Johnson Runs 6.889/203.06, Now #13; No Prior Run
Right Lane: Larry Morgan Runs 7.030/202.21, Now #14; No Prior Run
Johnson is straight down the track...Kurt Johnson's incremental times: 60ft-1.064 sec., 330ft-2.925, 660ft-4.463/160.59 mph, 1,000ft-5.780.
Left Lane: Steve Spiess Runs 6.785/202.21, Now #13; No Prior Run
Right Lane: Ronnie Humphrey Runs 6.751/204.11, Now #10; Best prior run: 6.733/205.91, Was #10
Spiess with his quickest pass of the weekend...Steve Spiess' incremental times: 60ft-1.001 sec., 330ft-2.830, 660ft-4.357/161.30 mph, 1,000ft-5.673. No help here for Humphrey.
Left Lane: Buddy Perkinson Runs 6.787/202.82, Now #14; No Prior Run
Right Lane: John Gaydosh Jr No Time, Now #23; No Prior Run
Gaydosh makes a quick move toward the centerline and crossed the centerline. Perkinson with his quickest pass of the weekend to get in the show. Buddy Perkinson's incremental times: 60ft-1.021 sec., 330ft-2.840, 660ft-4.361/161.71 mph, 1,000ft-5.676.
Left Lane: Robert Patrick Runs 6.780/202.52, Now #13; No Prior Run
Right Lane: Bob Benza Runs 6.795/202.70, Now #16; No Prior Run
Patrick with his quickest pass of the weekend to get in the show. Robert Patrick's incremental times: 60ft-1.015 sec., 330ft-2.834, 660ft-4.356/161.56 mph, 1,000ft-5.670. Benza gets in on the bump.
Left Lane: Ron Krisher Runs 6.729/205.47, Now #9; No Prior Run
Right Lane: Steve Kent Runs 6.776/204.20, Now #14; No Prior Run
Kent shook right off the starting line and was able to drive through it. Kent gets into the show. Steve Kent's incremental times: 60ft-1.025 sec., 330ft-2.854, 660ft-4.367/162.78 mph, 1,000ft-5.674. Krisher with his quickest pass of the weekend to get into the show. Steve Kent's incremental times: 60ft-1.025 sec., 330ft-2.854, 660ft-4.367/162.78 mph, 1,000ft-5.674.
Left Lane: Richard Freeman Runs 6.752/204.42, Now #14; No Prior Run
Right Lane: Warren Johnson Runs 6.765/205.35, Now #13; Best prior run: 6.739/204.29, Was #13
Freeman with his quickest pass of the weekend to get in the show. Richard Freeman's incremental times: 60ft-0.996 sec., 330ft-2.821, 660ft-4.338/162.22 mph, 1,000ft-5.649. No help here for WJ...
Left Lane: V. Gaines Runs 6.749/204.76, Now #12; Best prior run: 6.736/204.45, Was #12
Right Lane: Jason Line Runs 6.726/204.70, Now #5; Best prior run: 6.717/205.66, Was #5
Line with a nice pass, but he won't improve. Jason Line's incremental times: 60ft-1.001 sec., 330ft-2.813, 660ft-4.324/163.08 mph, 1,000ft-5.626. Gaines with a good pass, but doesn't improve. V. Gaines' incremental times: 60ft-1.021 sec., 330ft-2.829, 660ft-4.341/162.70 mph, 1,000ft-5.647.
Left Lane: Greg Stanfield Runs 6.740/203.95, Now #10; Best prior run: 6.729/204.35, Was #10
Right Lane: Vincent Nobile Runs 6.737/204.45, Now #8; Best prior run: 6.725/205.44, Was #8
Greg Stanfield's incremental times: 60ft-1.005 sec., 330ft-2.816, 660ft-4.329/162.80 mph, 1,000ft-5.636.
Vincent Nobile's incremental times: 60ft-1.010 sec., 330ft-2.819, 660ft-4.329/162.90 mph, 1,000ft-5.635.
Left Lane: Rodger Brogdon Runs 6.724/205.16, Now #2; Best prior run: 6.696/206.45, Was #2
Right Lane: Shane Gray Runs 6.727/205.41, Now #7; Best prior run: 6.723/204.79, Was #7
Tim Freeman, Brogdon's crew chief went to the hospital last night complaining of chest pains and was held over night...the doctor's ruled out a heart attack , but wanted him to stay for some further tests. Brogdon with another good pass...Rodger Brogdon's incremental times: 60ft-1.001 sec., 330ft-2.815, 660ft-4.323/163.08 mph, 1,000ft-5.625. Gray was straight down the groove...Shane Gray's incremental times: 60ft-1.010 sec., 330ft-2.817, 660ft-4.327/162.80 mph, 1,000ft-5.630.
Left Lane: Erica Enders Runs 6.706/205.38, Now #4; Best prior run: 6.700/206.04, Was #4
Right Lane: Greg Anderson Runs 6.719/204.54, Now #6; Best prior run: 6.718/205.07, Was #6
This was a great drag race...the two quickest pass of the session. Erica Enders' incremental times: 60ft-0.997 sec., 330ft-2.802, 660ft-4.308/163.43 mph, 1,000ft-5.609.
Greg Anderson's incremental times: 60ft-1.002 sec., 330ft-2.808, 660ft-4.315/163.33 mph, 1,000ft-5.619.
Left Lane: Mike Edwards Runs 6.703/205.26, Now #1; Best prior run: 6.679/205.94, Was #1
Right Lane: Allen Johnson Runs 6.697/206.51, Now #3; Best prior run: 6.696/205.98, Was #3
This is a great drag race to wrap up qualifying...the two quickest passes of the session. Johnson with the quickest...Allen Johnson's incremental times: 60ft-1.000 sec., 330ft-2.802, 660ft-4.307/163.67 mph, 1,000ft-5.604. Edwards was right there with him. Allen Johnson's incremental times: 60ft-1.000 sec., 330ft-2.802, 660ft-4.307/163.67 mph, 1,000ft-5.604.
Old 06-18-2011, 03:27 PM
Final Qualifying
Sat, 18 Jun 2011, 05:58 PM
Pro Stock Qualifying Notes, Final Session
By Rick Green
BRISTOL, Tenn. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 11th annual Ford NHRA Thunder Valley Nationals presented by Tri-Cities Area Ford Dealers listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Right Lane: John Gaydosh Jr Runs 6.984/198.52, Now #23; No Prior Run
Gaydosh ois straight down the groove, but he will not get in the show.
Left Lane: Frank Gugliotta Runs 6.838/202.12, Now #21; Best prior run: 16.568/46.01, Was #22
Right Lane: Kurt Johnson Runs 6.784/202.97, Now #17; Best prior run: 6.889/203.06, Was #20
Johnson with his best pass with this new car, but just misses getting in the show. Gugliotta with his quickest pass of the weekend, but he won't get in the show.
Left Lane: Larry Morgan Runs 6.737/204.63, Now #13; Best prior run: 7.030/202.21, Was #22
Right Lane: Buddy Perkinson Runs 6.768/203.03, Now #16; Best prior run: 6.787/202.82, Was #19
Morgan with his quickest pass of the weekend to get in the show. Larry Morgan's incremental times: 60ft-1.005 sec., 330ft-2.817, 660ft-4.330/162.63 mph, 1,000ft-5.635. Perkinson with his quickest pass of the weekend to get in the show. Buddy Perkinson's incremental times: 60ft-1.008 sec., 330ft-2.823, 660ft-4.343/161.96 mph, 1,000ft-5.659.
Left Lane: Bob Benza Runs 6.850/201.70, Now #21; Best prior run: 6.795/202.70, Was #21
Right Lane: Steve Spiess Runs 6.765/203.34, Now #16; Best prior run: 6.785/202.21, Was #20
No help here for Benza and he will not get in the show. Spiess with his quickest pass of the weekend and he gets in the show and that bumps out Perkinson. Steve Spiess' incremental times: 60ft-1.000 sec., 330ft-2.823, 660ft-4.345/162.08 mph, 1,000ft-5.658.
Left Lane: Steve Kent Runs 6.753/204.08, Now #16; Best prior run: 6.776/204.20, Was #18
Right Lane: Robert Patrick Runs 6.779/202.88, Now #19; Best prior run: 6.780/202.52, Was #19
Patrick with his quickest pass of the weekend, but he will not get in the show. Kent with his quickest pass to get in the show and that bumps out Spiess. Steve Kent's incremental times: 60ft-1.001 sec., 330ft-2.826, 660ft-4.343/162.06 mph, 1,000ft-5.650.
Left Lane: Warren Johnson Runs 6.741/205.29, Now #14; Best prior run: 6.739/204.29, Was #14
Right Lane: Richard Freeman Runs 6.760/203.71, Now #15; Best prior run: 6.752/204.42, Was #15
A couple good pass, but neither driver improves. Warren Johnson's incremental times: 60ft-1.015 sec., 330ft-2.828, 660ft-4.340/162.76 mph, 1,000ft-5.642.
Richard Freeman's incremental times: 60ft-1.006 sec., 330ft-2.820, 660ft-4.340/162.14 mph, 1,000ft-5.653.
Left Lane: Ronnie Humphrey Runs 6.719/205.35, Now #7; Best prior run: 6.733/205.91, Was #11
Right Lane: V. Gaines Runs 6.744/205.16, Now #12; Best prior run: 6.736/204.45, Was #12
Gaines with a good pass, but he doesn't improve here. Humphrey with a great pass to get in the top half of the show. Ronnie Humphrey's incremental times: 60ft-0.999 sec., 330ft-2.812, 660ft-4.322/163.02 mph, 1,000ft-5.622.
Left Lane: Vincent Nobile Runs 6.716/205.88, Now #5; Best prior run: 6.725/205.44, Was #9
Right Lane: Greg Stanfield Runs 6.740/204.01, Now #11; Best prior run: 6.729/204.35, Was #11
Weather conditions: air temperature 73 degrees, relative humidity 73 percent, barometer 28.38 inches, adjusted altitude 3,560 feet, track temperature 93 degrees.
Stanfield with a good pass, but he will not improve...Nobile with his quickest pass of the weekend to get in the top half of the show. Vincent Nobile's incremental times: 60ft-0.996 sec., 330ft-2.808, 660ft-4.318/162.96 mph, 1,000ft-5.620.
Left Lane: Shane Gray Runs 6.716/204.60, Now #7; Best prior run: 6.723/204.79, Was #9
Right Lane: Ron Krisher Runs 6.705/205.91, Now #5; Best prior run: 6.729/205.47, Was #10
Gray with his quickest pass of the weekend to get in the top half of the show. Shane Gray's incremental times: 60ft-0.987 sec., 330ft-2.794, 660ft-4.309/162.20 mph, 1,000ft-5.615. Krisher launched hard and runs the quickest pass of the round to get into the top half of the show. Ron Krisher's incremental times: 60ft-0.996 sec., 330ft-2.803, 660ft-4.311/163.47 mph, 1,000ft-5.611.
Left Lane: Greg Anderson Runs 6.711/205.26, Now #6; Best prior run: 6.718/205.07, Was #9
Right Lane: Erica Enders Runs 6.703/205.04, Now #4; Best prior run: 6.700/206.04, Was #4
Enders has a bracket car this weekend with another 6.70...Erica Enders' incremental times: 60ft-0.993 sec., 330ft-2.795, 660ft-4.301/163.00 mph, 1,000ft-5.605. Anderson with his quickest pass of the weekend to move into the top half of the show. Greg Anderson's incremental times: 60ft-0.997 sec., 330ft-2.807, 660ft-4.315/163.26 mph, 1,000ft-5.615.
Left Lane: Jason Line Runs 6.719/204.76, Now #9; Best prior run: 6.717/205.66, Was #9
Right Lane: Rodger Brogdon Runs 6.706/205.26, Now #2; Best prior run: 6.696/206.45, Was #2
Brogdon with a nice pass, but doesn't improve...Brogdon with the third quickest pass of the session. Rodger Brogdon's incremental times: 60ft-1.001 sec., 330ft-2.806, 660ft-4.311/163.45 mph, 1,000ft-5.610. Line is just a few ticks off his qualifying time. Jason Line's incremental times: 60ft-0.994 sec., 330ft-2.808, 660ft-4.319/163.04 mph, 1,000ft-5.620.
Left Lane: Allen Johnson Runs 6.668/206.89, Now #1; Best prior run: 6.696/205.98, Was #3
Right Lane: Mike Edwards Runs 6.678/206.42, Now #2; Best prior run: 6.679/205.94, Was #1
Edwards with his quickest pass of the weekend, but will give up the number one spot to Johnson. Mike Edwards' incremental times: 60ft-0.986 sec., 330ft-2.787, 660ft-4.290/163.97 mph, 1,000ft-5.586. Johnson launched hard and keep it hooked up to go to the number one spot. Allen Johnson's incremental times: 60ft-0.987 sec., 330ft-2.784, 660ft-4.285/163.99 mph, 1,000ft-5.579.
Old 06-20-2011, 05:48 AM
Eliminations
Sun, 19 Jun 2011, 11:02 PM
Summary of Eliminations in Pro Stock
BRISTOL, Tenn. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 11th annual Ford NHRA Thunder Valley Nationals presented by Tri-Cities Area Ford Dealers:
Round 1:
Jason Line, Mooresville NC, '09 GXP, Right lane, (0.034) 6.704 204.20 def. Shane Gray, Denver NC,'09 GXP, (0.038) 6.721 205.38
Vincent Nobile, Dix Hills NY, '11 Avenger, Right lane, (0.009) 6.715 204.88 def. Ronnie Humphrey,Jacksonville NC, '08 GXP, (0.081) 6.720 204.91
Greg Anderson, Mooresville NC, '09 GXP,Right lane, (0.005) 6.710 204.32 def. Greg Stanfield,Bossier City LA, '09 GXP, (0.032) 6.726 204.17
Erica Enders, New Orleans LA, '10 Cobalt, Right lane, (0.025) 6.690 205.41 def. Larry Morgan,Newark OH, '11 Mustang, (0.019) 6.745 205.10
Rodger Brogdon, Tomball TX, '09 GXP, Right lane, (0.018) 6.724 205.51 def. Warren Johnson, SugarHill GA, '08 Cobalt, (-0.059 foul) 6.758 204.42
Allen Johnson, Greeneville TN, '11 Avenger, Right lane, (0.034) 6.706 206.32 def. Steve Kent,Lottie LA, '09 GXP, (0.051) 6.758 203.61
Mike Edwards, Coweta OK, '09 GXP, Right lane, (0.082) 6.701 205.44 def. Richard Freeman, PaulsValley OK, '09 GXP, (0.091) 6.736 204.42
Ron Krisher, Warren OH, '09 GXP, Right lane, (0.088) 6.724 205.29 def. V. Gaines, Lakewood CO, '11Avenger, (-0.008 foul) 6.723 204.45
Round 2:
G Anderson, Right lane, (0.010) 6.702 205.10 def. R Brogdon, (0.036) 6.748 203.43
A Johnson, Left lane, (0.027) 6.679 206.45 def. J Line, (-0.005 foul) 6.694 204.63
M Edwards, Right lane, (0.010) 6.697 205.91 def. V Nobile, (0.012) 6.708 205.19
E Enders, Right lane, (0.026) 6.693 205.63 def. R Krisher, (0.045) 6.683 205.79
Round 3:
M Edwards, Left lane, (0.027) 6.708 204.82 def. G Anderson, (0.039) 6.710 204.98
E Enders, Right lane, (0.014) 6.697 205.26 def. A Johnson, (0.020) 6.692 205.41
Round 4:
M Edwards, Left lane, (0.093) 6.685 205.79 def. E Enders, (0.040) 11.863 72.89
Low ET: Allen Johnson 6.668 seconds
Top Speed: Allen Johnson 206.89 MPH
MReeves
06-20-2011 05:59 AM
MReeves
Funny Car
06-20-2011 05:56 AM
MReeves
Stock Eliminator
06-18-2011 06:17 PM
MReeves
Super Stock
06-18-2011 06:16 PM
MReeves
Super Gas
06-18-2011 02:53 PM
Quick Reply: NHRA Thunder Valley Nationals Bristol
