318 Poly missing Valve Lash Adjusters HELP!
Old 10-15-2016, 09:21 PM
Olie24's Avatar
Hi there, i recently swapped a 318 poly into my 67 dodge d200 that had a slant six and I just got it runni g good enough to drive.
Anyways, i went to adjust the valves on it, and after pulling the valve covers, there was no studs or anything for adjusting the valve clearances.
I was stumped and now I am wondering how i am supposed to adjust them? Or if i even can and why it was no studs or screws? Ill post a pic below so you all know what im getting at here.
Any help is appreciated. Thanks!
Attached Thumbnails 318 Poly missing Valve Lash Adjusters HELP!-20161014_222532.jpg   318 Poly missing Valve Lash Adjusters HELP!-20161014_222528.jpg
Old 10-17-2016, 10:29 PM
My guess would be that you have hydrolic lifters no adjustment needed.. Check clearance when the valve is closed
Old 10-18-2016, 07:29 PM
I dont remember how the poly's got adjusted.... If memorie serves me rite? I thought they used valve stem caps to take up clearance on them old dogs?
I think some guys went to adjustable push rods or rocker arms from a later poly motor... Sorry.
Old 02-06-2017, 04:27 PM
t65fury3's Avatar
did you find out to adjust i have a 65 poly
tcgrump
02-04-2016 01:20 PM
Mrpyro187
11-16-2012 09:09 AM
Mr. Belvedere II
06-21-2012 09:52 AM
smackhonda
05-14-2010 05:30 AM
DUST360
10-11-2009 09:54 AM
Quick Reply: 318 Poly missing Valve Lash Adjusters HELP!
