360 to 360 swap
I have a 1997 ram 2500 and I want to put an early 360 in it. As it is much cheaper to build a pre- magnum 360. My truck is manual 5 speed transmission 4x4. I'm just wondering if anyone knows what it will take mechanically to get the engine in the truck. I'd like to keep the drive train in tact if possible. I need to know things like: are the bell housing bolt patterns the same, engine mount locations? Those types of things. any help would be greatly appreciated.
the 360 is externally balanced so you will need a weighted flywheel. one motor mount is different the difference its the width you can use washer to make up the slack. everything else is just wrenching.
and what tim said above |
I think you are thinking wrong. If you want to get rid of EFI and go carb, build the magnum. It has way better heads and the roller cam lasts a lot longer than LA setups.
