Go Back   Mopar Forums > GENERAL > Do-It-yourself Section
Thread Tools Display Modes
Old 07-29-2008, 08:39 PM   #1 (permalink)
67 GTX
Bent Push Rods
BENT PUSH RODS
Hi, I have a 1967 Plymouth GTX 440. The engine is completely stock except for headers and a cam. I am having trouble with it lately. The push rods on one valve keep bending. There was a ticking sound coming from the rocker, and now that just stopped. When we put the new push rod in, we noticed the the engine was banging on one side. Once the lifter filled with oil again, the banging stopped. Then, I drove the car around the block. Came home, shut it off. A minute or so later, started the car, no oil pressure. This also happened last night on the highway near 5000 rpm, but we weren't doing that in the driveway. So, and help would be great.
67 GTX is offline   Reply With Quote
Old 07-30-2008, 05:10 AM   #2 (permalink)
Commando
Senior Member
Commando's Avatar
Did you replace the lifters when you put the new cam in?
Commando is offline   Reply With Quote
Old 07-30-2008, 09:35 AM   #3 (permalink)
67 GTX
I didn't replace the cam. When I got the car, I just had to put the heads and intake manifolds back on. I'm not sure what kind of cam it is, but it isn't an all-out racing one.
Old 07-30-2008, 09:37 AM   #4 (permalink)
67 GTX
But I also put new lifters in when I did all of this.
Old 07-30-2008, 10:48 AM   #5 (permalink)
Commando
Senior Member
Commando's Avatar
Ok, I know a lot of issues can occur with the lifters if they are not replaced, especially if the lobes are bigger in the newer cam. The lifter could also be bad, might want to take it apart and check to see if its good.
Old 07-30-2008, 11:23 AM   #6 (permalink)
67 GTX
Thanks for your Reply.
That's probably what I'm am going ot do next. I really don't wanna replace the cam. It is a big job on this car.
Old 07-30-2008, 12:18 PM   #7 (permalink)
Commando
Senior Member
Commando's Avatar
Definitely if you have it in the car, I put one in my 440 a couple months ago, but I had it out of the car anyways.
Still out of the car for that matter, but I can't help myself breaking bolts and delaying the install.
Old 11-06-2008, 04:58 PM   #8 (permalink)
74fldart
Junior Member
if a pushrod bends and allows a lifter to pop up or out of its bore, you will lose oil pressure. i think you have a cam that wasnt installed right or the timing chain a tooth or two off. this will cause your problem, it happened to me. you might have a piston to valve interference problem also.
74fldart is offline   Reply With Quote
Old 11-06-2008, 05:33 PM   #9 (permalink)
67 GTX
i already fixes the problem
it had to do twith the zinc being taken out of the oil
it causes the lifters to fail, and the cam
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bemp Push Rods 67 GTX B-Body 2 07-30-2008 09:41 AM
Cracked Cap Rods unclemike Neon / SRT-4 1 10-11-2007 07:31 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
