Diy head porting disaster.
Old 10-14-2015, 03:53 AM
Zmartin17's Avatar
Hi everyone, new to the forum, life long Mopar guy. So here's my problem. I tore down my 87 360 to get a couple of broken manifold bolts extracted. I'm looking at cams and some other things to throw at it when I put it back together to give my old truck a little more life. So I decided to do a port job on the heads. No big deal, I've done it before. Until I found a thin spot on the intake port... There's now a hole about the size of a match stick going through the wall of the intake port into the bolt hole for my valve cover. Now what????
Thanks
Old 10-14-2015, 06:16 AM
Magoo's Avatar
Smile WELCOME
Welcome and Good Luck. -- All things get better with time.
Old 10-14-2015, 09:22 AM
Drag Pak's Avatar
Put a stud in it. Or cover it with epoxy.
Old 10-15-2015, 08:18 AM
Rooty's Avatar
Probably you can use JB Weld to fix the spot. Use the one that is high in metal content and after it cures, mold it to a desirable shape.
Old 10-15-2015, 10:11 AM
Magoo's Avatar
Thumbs up JB weld
--- I agree. I used it to seal up a porous 440 block that oozed coolant. I roughed the area with a power wire brush and then applied 2 layers of it. -- Smoothed it, when dry, and the problem was gone.
Old 10-15-2015, 10:12 PM
moe7404's Avatar
ill tell you this story if you dont laugh. on a 360 i thought it needed alinement pins in the chain cover. i spent 6 hours to find the right spot. one went into the water jacket. so out comes the JB-weld.
Old 10-16-2015, 07:01 PM
I'd do the Stud....
Old 11-02-2015, 12:33 AM
DodgeAddict's Avatar
I'd do the Stud....
So would I
woody02
11-06-2012 08:04 AM
1966DartConvertible
10-27-2012 05:55 PM
1966DartConvertible
05-13-2012 08:11 PM
deadkelly
04-01-2010 04:02 PM
Slice
01-19-2010 12:33 PM
Quick Reply: Diy head porting disaster.
