Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
hi,i have a '61 dodge p-300. a 1 ton stepvan.it has the original 4spd trans.i would like to have a later model overdrive manual trans for it.one that i can use the existing bellhousing with.i know i may have to change the clutch disc and modify the driveshaft.i just need to know which tranny to use.any suggestions? thanks,pat
#2 (permalink) |
MasterDebater
WOW ... you have got to do alot of comparing. Input shaft lengths, spline diffs, pilot bushing ID's ....etc.
#3 (permalink) |
Ph.D in wheelinology
what do you have for a motor?
__________________
Tim and Heather 1974 J10 - getting built up some more. built 360, built TH400, D300, D60(detroit)/14B(spool), SOA, inboard rear 64" springs, 38.5 thornbirds jeep pics - http://s149.photobucket.com/albums/s63/jeeping1974/J10/ |
#4 (permalink) |
Junior Member
hi,the p-300 has a 318 w/4bbl, and torque cam.this has carried me to alaska and back as well as all over the lower 48.it has 4.10 gears [spicer 70].and i'd like better gas mileage..pat
#5 (permalink) |
like Doc said, you'll have to do some measuring. I'm sure that Advance adaptors has something that you will help you adapt an OD manual to your LA 318.
__________________
#6 (permalink) |
MasterDebater
I would look at putting on a set of taller tires or maybe a spread-bore carb ...aka a ThermoQuad.
#7 (permalink) |
Junior Member
hi.i put 17.5" rims and tires on it 18 yrs ago.and i'm using a holley econo master carb..an overdrive trans is what i need.thank you..
#8 (permalink) |
what about installing an auto like an A518 (I think thats the one with OD).
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1979 dodge truck stepside | petree1 | Mopar Classifieds | 3 | 01-21-2008 10:17 PM |
| Bought my parts truck. | ccflash22 | General Discussion | 3 | 11-26-2007 06:24 AM |
| 340 power problems in a truck | ddale | General Technical Questions | 2 | 02-01-2007 05:46 PM |
