Go Back   Mopar Forums > GENERAL > Do-It-yourself Section
Thread Tools Display Modes
Old 07-19-2008, 09:02 AM   #1 (permalink)
vitaminc383
'70 road runner 383
vitaminc383's Avatar
Engine paint questions
Redoing underhood on '70 Roadrunner 383..
Does anyone know what finish the factory actually used on engines? Trying to find out if was no-gloss, low-gloss, or high gloss. Seems like a lot of restos have a high gloss finish, but I thought I read somewhere that the factory used low-gloss??
I'm using the Dupli-color hemi orange 500 degree. Stripped valve covers down to bare metal, primed with the Duplicolor 500 degree gray prmer. The pic shows after 1 coat of the color, and it looks sort of low gloss. Don't know if a second coat will turn out more gloss. Duplicolor makes a 500 degree clear.... don't know if it's good to go that route for gloss.
Plan to do same with intake, only pulled off intake, vc's, and exhaust manifolds, will paint engine in the car.
While I'm at it.... if you look at the pic, on bb valve covers, does anyone know what was attached where the 3 broken tabs are? I'm assuming it was some sort of clip to hold the wiring harness to the alternator. If so, wonder what I can do here, instead of resorting to welding. Also, the plug wire holders, was there some type of plastic insert in these? the plug wire sits in them pretty loose.
Thanks.....
vitaminc383 is offline   Reply With Quote
Old 07-19-2008, 09:22 AM   #2 (permalink)
Doc
MasterDebater
Doc's Avatar
I would say you are good-to-go with that lo-gloss. The D C paint you are using is good stuff.
Doc is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mopar high heat paint Commando Do-It-yourself Section 27 10-26-2008 03:59 PM
'67 Charger paint El Destructo Inc General Discussion 0 06-12-2008 12:18 AM
318 Build-up Questions 73DartSport General Technical Questions 3 03-06-2008 05:02 PM
I have a few questions about my 66 Fury III. team39763 General Discussion 5 01-20-2008 06:42 AM
Questions about J Heads? crown_coupe General Technical Questions 3 12-23-2007 09:57 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
