Existing coil with electronic ignition...ok?
Old 06-01-2014, 08:56 PM
labradorian70's Avatar
Switching over points system to electronic ignition on a 383 in a 66 dodge monaco .......I'm installing proform 361,383,400 conversion kit. Part no. 66993 at www.proformparts.com
someone mentioned to me that some of the older coils are not compatible with the electronic ignition systems. Different voltage levels Im guessing.
On my car is the delco remy part# 1115202 coil. Will I be ok to continue to use this with electronic system or do i Need to upgrade it.
Thanks
Glen
Old 06-02-2014, 09:10 AM
If your getting anything other than what the instructions say to operate the new system. Then it's going to give you trouble....
Old 07-22-2014, 07:56 PM
I finally got around to installing this HEI kit, I did switch out the coil with one I knew was for an electronic ignition. The car is back up and running again.
cheers
Glen
Old 07-22-2014, 08:56 PM
Good Deal...
gkaucher
08-13-2012 05:32 PM
stazja01
11-17-2008 04:24 AM
tish
10-20-2008 05:43 PM
318dart
05-20-2008 12:14 AM
theaspenator
01-30-2008 06:30 PM
Quick Reply: Existing coil with electronic ignition...ok?
