HEADERS
Looking to find somewhere to buy some headers for my 1989 Dodge D-100,
With a 239CI 3.9L V6. No auto part stores sell them for my truck, And I tried Jegs and summit, no luck either, anyone know where i could find some for my truck? |
I'm not sure if anyone sells them. You have two options, either get a header kit and make you own (or have an exhaust shop do it for you) or see if you can retro fit a pair for a ram 1500. Either way, you are probably looking at a good amount of money for what little gain they will give you on that motor in that truck.
What you should do is save up your money and swap in a 318/518A or 727 in place of that V6. You'll have more power and a lot more options for add-ons. Not to mention that you would probably spend the same amount buying that combo and swapping it in as you would on a set of headers for that truck. |
I second the motion
78D is right on the money!! 3.9 has the same bellhousing pattern I think. You should be able to put a 318 in it's place without much fuss.
Originally Posted by grissomracing
(Post 30277)
X2 on all of that.
Put one of those new Hemis in that Dak.
Originally Posted by old tired rebel
(Post 30300)
Now you are talking!!!!!!! |
Originally Posted by MReeves
(Post 30335)
Im thinking that if the exhaust dumps are in the same location as the v-8 daks. then id consider using the headpipe from a v-8 dak, or get the head pipe then cut the ends off and use your flanges on the headpipe, then use an 8 cyl. exh. all the way out, The pipe is probly 1/2 in bigger in size, and a little less restrictive. at least youll get some bettter flow out of it, and not spend as much for an 8 cyl. swap. then you can have your ecm. remapped for the exh. change.as far as lean to rich mixture, and timing changes.
