help wiring wiper motor
I tried a forum search but came up empty, I have a 1973 Cuda and had to wire the entire car, we used the Painfull brand harness but it has no wiper wires just 1ea wiper power wire, I need a picture of the back of the switch showing what colors go from the switch to the motor and where please.
2 Attachment(s)
thanks John, but I do not have any original wires so I need to know exactly what wire goes where.
Wiper wiring
If you look at the schematic John posted you will see numbers in square blocks with wire colors. They are numbered 1 thru 8 and the blocks beside are also numbered 1 thru 8 like a mirrow image. This is the male/female plug connector.
Numbers 1=Brown 2=Red 3=Brn/Yel. These go to the wiper motor. If you use the corespong schematic you will find where these go on the wiper switch. Links for both schematics are below. http://www.mymopar.com/downloads/1973/73BarracudaA.JPG http://www.mymopar.com/downloads/1973/73BarracudaB.JPG |
thanks roadrunner, but I have no harnes at all so its good to know what color goes from the switch to the motor unfortunatley it does not show on what post on the motor they go to.
This might be the easy way out.http://www.yearone.com/serverfiles/f...321n&SM=1&SC=1
