isoclamp removal
Old 04-21-2009, 06:10 PM
Senior Member
craveman's Avatar
isoclamp removal
i would like to remove the isoclamp system from my fifth avenue but dont know how. what parts do i need to use to do this and how do i do it?
Old 04-24-2009, 02:41 PM
Polaradude's Avatar
Gotta ask dude, what the hell is an isoclamp ? Does penicillin work ?
Old 04-24-2009, 03:34 PM
scotts74birds's Avatar
Its a rubber doughnut sandwiched between the spring perch and the frame at the leaf springs. Either that or it is a piston return spring compressor.
Old 04-24-2009, 11:33 PM
rr69half6bbl's Avatar
no, no scott, you start mis informing polara and he gets all wound up. ok polara, an iso clamp, is the english venacular for a pair of large pliers that keep your but cheeks together while in an all male shower party, I.E. ISo clamp. say it with a little hint of aussie,. LOL craveman, if your referring to scotts descrip, then if you have a local weld shop, take the old 1 in to then and have them weld up a block of 3/16`s late, basically make it a solid spring mount, that will solve your prob. i know that the isolatores were bad about rotting out. the front k frame isolators were notorious for that,
Old 04-25-2009, 06:49 AM
Polaradude's Avatar
RR69,Can't say I've ever been to one of them, but I'll take your word for it.
TwistedWrenches
05-16-2009 10:51 AM
68camperspecial
04-02-2009 01:46 PM
Captainkirk2931
01-06-2009 11:37 PM
68 Sat
12-22-2008 09:00 AM
Monacoman
08-14-2008 01:35 PM
Quick Reply: isoclamp removal
