Mapping my DIY Electronic Ignition :)
2 Attachment(s)
Got my distributor fixed, now mapping the ignition timing vs. RPM vs. load using the handheld trigger.
I can retard/advance the ignition timing at every 300rpm increments (or 500rpm increment if you wish) (15 steps i.e. 0 - 4500rpm) vs. load (throttle). Here is a picture or two : Attachment 14231 and here ive also fitted the 3-3/8" Sun Pro Tacho on the column (can't fit on top, no clearance) Attachment 14232 :) Syed Malaysia |
Excellent post!! Did you do / make that yourself or are you using a specific part in a custom application? If it's the latter could you tell me what part / parts you are using?
That is a great looking car! |
