ram 1500 slant 6 to 318 swap
Old 11-28-2010, 11:45 AM
mopar2719's Avatar
i have a early 80s ram truck that has a slant 6 in it and want to drop a 318 from a 85 ram charger and still have the ramcharger for parts what will i need to do the swap and is it even worth it for the work ill have to do.
Old 11-29-2010, 06:04 AM
The truck and Ramcharge frames for the motor area are the same so everything should just bolt right together.
Swapping from a slant 6 to a small block V8 will be noticable. These are pretty heavy trucks for a 6 cylinder. Depending if hte motor is TBI or carb, you may want to add on some performance upgrades (headers, intake, carb, pulleys, etc.) while swapping the V8 in.
Old 12-03-2010, 12:36 PM
rr69half6bbl's Avatar
Tim, I thought the slant six k`s on the trucks were like the cars, and you needed an adapter kit. So the 6 mounts are square blocks like the 8`s and you can just use the 8 mounts on the saddle?
Old 12-04-2010, 12:32 PM
theomahamoparguy's Avatar
same frame /6 to V8No probs. (doing this right now to my w150)
Old 12-06-2010, 03:17 AM
The rubber mounts are different but the mounts that are welded/pop rivited to the frame are the same. At least the ones on my old 85 D100 were and that was the same frame that was used from 1972 til 1993 [they changed the body style but not the frame between the third (1972-1980) and fourth generations(1981-1993).]
MonroePRacing
01-04-2012 07:00 PM
johnthegoalie
06-30-2009 01:45 AM
plymouthrr1985
05-25-2009 05:22 PM
Ekimwood
03-15-2009 04:40 AM
johnny4915
11-29-2008 05:05 AM
Quick Reply: ram 1500 slant 6 to 318 swap
