Go Back   Mopar Forums > GENERAL > Do-It-yourself Section
Thread Tools Display Modes
Old 07-31-2008, 08:13 PM   #1 (permalink)
67 GTX
Removing the cam
On a 1967 Plymouth GTX 440, can the cam be removed through the front grill, or does the engine have to come out?
67 GTX is offline   Reply With Quote
Old 08-01-2008, 12:42 AM   #2 (permalink)
Doc
MasterDebater
Doc's Avatar
You JUST have to pull the radiator.
Doc is offline   Reply With Quote
Old 08-01-2008, 05:02 AM   #3 (permalink)
Commando
Senior Member
Commando's Avatar
Do you just pull the radiator or do you also have to pull the condenser? I am not sure on this but from what I have seen it looks real close to not coming out because of the condenser, but that may depend on the setup under the hood.
Commando is offline   Reply With Quote
Old 08-04-2008, 04:12 PM   #4 (permalink)
challenger
challenger's Avatar
Send a message via Yahoo to challenger
Commando you have to pull the Rad: and the condenser and anything else that looks to be in the way you wont be able to turn the cam to get it out unless you do so ... the cam is appox; 18 to 19 inches long so you might even have to take the grill out as to not nick the cam also make sure the hood latch mech: is out of the way
challenger is offline   Reply With Quote
Old 08-05-2008, 03:26 AM   #5 (permalink)
Doc
MasterDebater
Doc's Avatar
Quote:
You could be right Chally ... I have never pulled a cam in a 66-67 B body. I have done it in a early B body(62), later B body(69) and in an E body(71 and 73) .... all I have ever had to do is pull the rad. But none of those other cars had any AC stuff on it.
Old 08-05-2008, 05:09 AM   #6 (permalink)
Commando
Senior Member
Commando's Avatar
If you were to pull it out of my B-body, you have to pull the radiator and condensor, as there is still more room before the grill, But it still has to be able to come all the way out.
Old 08-07-2008, 08:50 PM   #7 (permalink)
challenger
challenger's Avatar
hey doc it can be done as i have changed cams right at the track to try them out and pulled just the rad; but my worries with friends is im always looking out so they don't nick them in anyway as you and i both know it can ruin the day with a gouge in your cam but he will have to remove the ac condensor
Old 08-07-2008, 08:53 PM   #8 (permalink)
challenger
challenger's Avatar
p.s you shouldn't have to remove the lines to the condensor but move it as far forward as possible k
Old 08-07-2008, 08:57 PM   #9 (permalink)
Doc
MasterDebater
Doc's Avatar
OK Chally ... how much more room is there in a 70-74 E body ?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Removing the cam 67 GTX B-Body 35 10-03-2008 08:25 PM
Roller cam for LA motor bad_karma Dodge Ram 1 08-28-2008 03:03 PM
360 LA Cam Options Boneheadjoe General Discussion 3 07-19-2008 09:25 AM
360 + melling spd-22 cam JuhKiv83 Performance parts and engine development 1 11-20-2007 08:19 AM
Cam identification, need help bcuda65 General Technical Questions 1 04-26-2007 05:38 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
