transmission leak?
Old 04-04-2009, 12:25 PM
68 Sat's Avatar
transmission leak?
looking for some help with this leak. Started about 8 weeks ago and is a small drip. Noticed the spot in the garage. Seems to be at the area where the trans meets the drive shaft. Any thoughts are helpful..oh yeah it's a 68 Sat with a 904 LA..
Attached Thumbnails transmission leak?-dsc05605.jpg   transmission leak?-dsc05607.jpg   transmission leak?-dsc05609.jpg   transmission leak?-dsc05610.jpg
Old 04-04-2009, 02:47 PM
Originally Posted by richinny
transmission tail shaft seal
X2.
Old 04-04-2009, 03:43 PM
Commando's Avatar
The seal sounds like the issue to me, is it the original rear axle as the drive shaft looks like it's pushed in pretty far.
Old 04-04-2009, 04:00 PM
68 Sat's Avatar
i believe it is the originalrear axle..Can I change this myself?
Old 04-04-2009, 07:31 PM
Commando's Avatar
Yes, first you have to remove the driveshaft and then remove the old seal and then tap in a new one. It's just like any other oil seal.
Old 04-05-2009, 03:55 AM
jack up the back end and put some lack stands under it so that the back end is up in the air. if it is high enough, tranny fluid won't come out. make sure that you have a bucket under it though when you start.
demetri
02-26-2014 07:32 PM
jerzjer
04-29-2011 03:02 PM
66coronetgirlie
08-09-2010 10:41 PM
sgp7679
04-07-2009 07:22 AM
wheelman487
01-03-2008 08:54 PM
Quick Reply: transmission leak?
