1967 440 engine question.
Old 11-15-2012, 07:52 AM
Younggun's Avatar
I found a guy who is selling a 1967 440 paired with the original 727. It came off a motorhome. My question is, are the motorhome engines the same used in the cars? Is there a difference in compression etc...
Old 11-15-2012, 12:23 PM
Yes and No. Maybe 1/2 point lower. It depends on the heads some have the water pump mounted up hi to the heads which would have to be changed along with the heads them self, and probably the oil pan. The trans It depends Some of the bigger motor homes use a HD version of the 727 called a load flight ? It is physically larger. SO you need to see pictures. Could be a good deal or a bucket of bolts
71RR08
05-27-2016 03:34 AM
rockinhlabs
08-29-2012 10:15 AM
timmymacnj
05-20-2010 09:37 AM
carlosg7915
02-20-2010 10:51 AM
Rico1969
06-05-2009 03:14 PM
Quick Reply: 1967 440 engine question.
