225 to 318 Swap
Old Sep 13, 2008 | 07:11 PM
fpereira23's Avatar
Junior Member
225 to 318 Swap
Hi Guys,
I think I finaly found the engine to swap the 225 in my 69 Dart.
I found a 73 Coronet with a 318. I'm buying the whole car for $500. I was planning on using the engine and transmision, however I've been told that the coronet's crossmember will bolt right into the Dart so that I won't need the Schumacher engine mounts....Is this True???
Also, will I also need to use the drive shaft and rear end? Will this be a good idea or should I stay with the Dart's ones. Will they fit or will I need to modify something in my Dart?
What other part do you think I could use from this 73 Coronet on my 69 Dart? Steering...etc??
TKS
Old Sep 14, 2008 | 09:42 AM
ef8340's Avatar
Senior Member
doc is correct the k-frame wont interchange the motor and trans will, also some lightbulbs and fuses,& cig lighter, the driveshaft and rear will be different aswell and wont bolt up
SspazZ
Jul 29, 2014 03:35 PM
Arich
May 25, 2012 12:28 PM
225valiant440
Jul 16, 2011 09:55 AM
mrblond750
Jun 23, 2010 05:55 PM
MuscleCrazy
Feb 22, 2009 01:54 PM
