360 Magnum Hughes Heads
Hi, Im new here to the forum. This is my first post. I recently purchased a set of Iron Ram EQ heads for a magnum from Hughes and had a valve job done locally. They cam out very nice. They are the 1.92 valve size. This was in October. I am still building the engine and have changed direction a bit and decided to go with a bigger valve 2.02. I am reordering a set or EQ heads from hughes with the 2.02 valves and selling the other heads. My question is, how is the valve job that hughes does. I know it comes standard on the 2.02 heads. Is it a quality job? Thanks
Bottom Line.... You on the rite track.... Always recheck and make sure it's all rite before installing them... If you dont do your own head work. Have your cylinder guy go over them to make sure it's going to be ok for your build..... As you will read, Some will say "ya" and others will say "naa"....
68Dart
03-17-2019 05:43 PM
