| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
413 or 383
i might buy a 68 monaco with a 383, or a 62 new yorker with a 413, I know they are about the same thing but is one better with stronger parts??
is the compression the same?? both are 4 barrel motors, and are the 727s the same or are the older like 62 models stronger? |
#2 (permalink) |
Senior Member
I'm not intimately familiar with the old New Yorkers, but the older transmissions had the wierd old U joint on the rear of the trans, and I cannot for the life of me remember what they are called. Not desirable
Furthermore, the early models had the tapered rear axles, which aside from being weaker, and more difficult to get parts for, require a huge big puller to remove the rear hubs. I'd buy the '68 if it were me |
#3 (permalink) |
Junior Member
413 vs 383
i should have mentioned i am going to buy one of them for motor tranny setup to go into my 68 coronet i have newer 727s but was wondering 413 or 383 wich one is stronger if any
#4 (permalink) |
Junior Member
I rode in a 71 fury fury once with a 413 in it 105 in 1st ride of my life
#5 (permalink) |
Junior Member
413 or 383
I never knew that a 413 engine was ever used in a car. What years and models used this engine? I thought it was only used in trucks.I would be interested in learning more.
#6 (permalink) |
Junior Member
they used them in the c bodies of the sixty's not sure bout the late fifty's but i do now they were in the sixty's the new yorker, and the imperial both had these for a while those are two cars that came to mind for me there are others but can't think of any right of the bat. Anybody else knows of any other ones?
#7 (permalink) | |
Senior Member
Quote:
(There's a certain amount of poignant thoughts in the old Beach Boys tune "Shutdown") http://www.lyricsfreak.com/b/beach+b..._20013813.html While the all-out 413's were pretty torquey, those manifolds were not known for "top end" However, they were pretty much the ancestor of the famous 426 max wedge: http://www.fortunecity.com/silversto.../45/wedge2.htm ![]() |
#8 (permalink) |
Junior Member
383 or 413
go with the 383. parts for the 413 are hard to come by and very expensive compared to the 383. the 413 was used in c-bodies from 1959 through 1965, when they were replace by the 440. the transmission in the 62 is also much more difficult to work with on a swap.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 413 Question | griz2575 | New Member Section | 5 | 06-24-2008 06:13 PM |
| Mopar 413 Motor Serial Number | glennmccann | New Member Section | 2 | 01-03-2008 11:04 AM |
| what is the cross symbol stamped next to 413 on my block | poolinstaller | General Technical Questions | 2 | 10-27-2007 07:34 AM |
| What does HT mean and the cross symbol on my 413 | poolinstaller | New Member Section | 1 | 09-13-2007 05:23 AM |
| 1930 413 Wedge Hemi | Cardude | New Member Section | 0 | 05-02-2007 03:57 PM |
