440 swap in a 318 duster help
Old 05-16-2010, 07:01 PM
dusterboy89's Avatar
i have a 72 duster with the stock 318 in it i bout a 440 to drop in it someone said u gotta change a bunch of stuff for it to work can somebody tell me what i gotta do
Old 05-16-2010, 07:19 PM
SCAMP TRAMP's Avatar
They made that job more easy ....
http://www.engine-swaps.com/
Old 05-17-2010, 04:27 AM
You should also look into changing out the torsion bars in the front suspension as I think there is a difference between the small block and big block weights.
You'll also want to change out yout radiator to a larger unit (meaning 3 or 4 core unit), you'll need a big block transmission to bolt up to the 440, you'll want to change out the rear end as the stock unit will not be able to handle the power and torque. I'm sure that they may be a few other things as well.
Old 05-21-2010, 10:48 PM
Junior Member
johnyhemi's Avatar
is there any header clearance problems this is essentially wat i had in mind when i find a duster
Maley
04-30-2014 06:16 PM
chlngr1970
09-30-2010 08:54 AM
TrustyDusty
08-06-2010 12:50 PM
theironman
02-06-2010 10:08 PM
dobaon22s
11-05-2008 01:42 AM
Quick Reply: 440 swap in a 318 duster help
