Are 5.9L Magnum engines any good?
Old 12-16-2014, 02:33 PM
74Runneer's Avatar
My friend calls me up and said he blew the rear main seal in his 1993 dodge 5.9 and asked if I wanted it because he was just going to scrap the truck. I have a Road runner with a 318 in it right now and was wondering if this is something I should snag in case the 318 dies on me.
Can these magnums be built for pretty cheap? I bought headers, performer intake, 600 cfm eddy, and a fbo ignition system (ecm, coil, dizzy) for my 318. Will any of these be able to transfer to the magnum?
What do you guys think?
Old 12-16-2014, 02:52 PM
Great snag for sure, all but intake manifold will work. Get the flywheel or flex plate/torque converter too.
Dan.
Old 12-16-2014, 07:07 PM
74Runneer's Avatar
Do most people keep the fuel injection or swap it out with a carb?
Old 12-17-2014, 12:45 PM
Depending on swap, swap to carb. stand alone fuel injection systems are expensive
Old 12-17-2014, 02:01 PM
If you keep it close to stock with OEM computer and full engine wiring harness, you can get a better running more reliable new engine in an older car, but that's not much fun.
If you computer search Magnum modifications/swaps you'll find mild to wild.
Old 12-19-2014, 12:01 PM
moe7404's Avatar
IMHO i would swap out the stock smog cam. and use a new cam about the same lift and duration as the stock cam but aftermarket. with a good double roller chain. 2-4 degrees advanced. never never go more than 4 degrees. and put brass soft plugs in the block. and JB-weld to hold them in.
Tom T2
08-23-2015 07:21 PM
lgad
12-08-2011 10:19 AM
Mango
09-13-2010 06:52 PM
skatefast91
07-16-2010 10:10 AM
bkreke
04-02-2008 08:14 PM
Quick Reply: Are 5.9L Magnum engines any good?
