74 cuda interior need help
I have a 74 cuda and I don't know where the seat belt shoulder harness routes thru the side panel. my side panel has no cut in it to feed the shoulder belt thru. The side panels were not in it when I got the car and I am now ready to put the in, but I am not sure where they go.
Thanks |
Not sure about 74 or E body, but my 72 roadrunner has the shoulder belt attached to the roof. Its all folded up on hook there and then can be pulled down and hooked onto the lapbelt.
Thanks, for trying to help. My belts attach to the headliner and then down to two places, one near the front seat and on near the back set. That I think goes thru the side rear set side panel, but my rear set panel has no opening tho feed the belt thru. Must be the wrong side panel.
Thanks for trying to help, Greg |
weather permitting i am headed to a mopar show on sat. I will check around there for you. otherwise i think there is a guy in my dads neighborhood with 74.
Well the show was barely a show. Rained most of the morning and about 20 cars showed up at the time I was there. There were a couple of 73's and they had belts like mine - two piece that has the shoulder strap folded and hung on headliner. I will tell my dad to talk to the guy in his neighborhood.
