74 Dodge Charger 318/auto/column shifter linkage question
3 Attachment(s)
What is supposed to attach to this bracket? Am I missing a part? I am ordering the correct bushings for the linkage brackets. TY.
The linkage is totally hooked up wrong.. The stud hole in the bell housing should have a stud with a swivel bracket for the kick down, depending on style. The linkage needs to be above the torsion bar The bracket needs to be rotated 180* on the frame - also looks like someone tried to bend it streight..
This car was a nightmare basket case when I bought it. Doesn't surprise me at all that it's hooked up wrong. I am ordering some new bushings and will consult Haynes Repair Manual and other sources. Hopefully, the info you gave me will start to make sense and become clear. TY TNLynn.
Here's a bunch, didn't look close enough to see if one is yours though.
http://www.moparts.org/Tech/Archive/auto/35.html |
One end of the cross shaft fits into the trans bracket (ORANGE BUSHING SHOWN IN THE TRANS PIX) The other end fits into the bracket that bolts to the frame- the bracket should have an index pin. then one rod goes from the bracket arm to the column other arm goes to the trans if that makes sense ?
The Fury 8 pix 8 for the trans kickdown ??? |
Coronet 500 hundred it the nail on the head for piture # 1
Looks like you missing some of the linkage there for the lick down. Piture 2&3 are just Shifter shafts and it looks like all you need are some new bushings... |
