Accel Universal wires
Old 12-22-2011, 06:52 PM
Arbiter343GS's Avatar
I just bought a set of accel universal spark plug wires and it came with a set if crimping jaws, I was wandering, how does one go about using them? Because I dont have a crimper(and the last set of universal wires I made was with a wire stipper, they didnt come out bad, but I dont want to rig this set).
Old 12-22-2011, 06:56 PM
Read the instructions...either squeeze them together in a vise or even hit it with a hammer. I have done it both ways.
Old 12-22-2011, 08:01 PM
crmzendrgone's Avatar
I also have use these methods.
Old 12-22-2011, 09:02 PM
The directions aren't very clear it just says to use accel wire clamps but you could also use the jaws which are a much cheaper alternative except you need toy use a vice with them.
Old 12-22-2011, 10:30 PM
How does the hammer method work?
Old 12-22-2011, 10:45 PM
Put the bottom half on the jaw on the ground...concrete...put the wire in and place the top jam on and hit it hard with a hammer...two people are best at that. If you have a vise put the bottom jaw and in the vise and repeat above procedure. One person is needed.
Old 12-22-2011, 11:43 PM
Cool, Thank you!
Old 12-23-2011, 05:47 AM
Archer's Avatar
A-
You might find it easier if you put the bottom half in a metal vise so the "bumps" stop it from sliding down and then set the vise resting on a hard surface. Lay the wire and connector in the recess and hold the top half over the wire. Once lined up, hit the back of the top half with a hammer - good luck.
09-27-2012 08:10 AM
Macjeep
06-19-2012 12:01 PM
jeff1010
08-06-2011 01:33 PM
Dustoff440
03-31-2011 06:35 PM
MagnumBlue
05-28-2010 03:35 AM
Quick Reply: Accel Universal wires
