Battery Charge Problem
Hey all I have a 1970 Plymouth Satellite that the battery doesn't want to charge on. I have had the alternator checked and it is okay. I have also replaced the voltage regulator. Does anyone have any insight as to why my battery might still not be charging.
This may be a stupid question, but have you had the battery tested as well? Autozone and most other stores will test it for free.
If the battery is not to old I would check the fluid and make sure that my connections are not corroded, although I may be stating the obvious. Is the battery completely dead? |
You could have a dead cell or a few dead cells in the battery. A loose ground somewhere, loose cables, connections count be loose or too dirty to make good contact. I'd have the battery tested first though.
Get a load test done on the battery.
if the bats. good, then back check all your wires from the alt. to the bat. make sure theyre not crimped, cut or loose.
