Go Back   Mopar Forums > GENERAL > General Discussion
Thread Tools Display Modes
Old 07-13-2008, 01:09 PM   #1 (permalink)
Dakota_Don
Junior Member
cam choice for a 410 SB stroker
HI , I HAVE A CAM QUESTION.
I am building a 410 (360) stroker
It has 587 cast iron heads, ported with 2.02 and 1.60 valves bowl work ect...
it flows aprox 250ish at 500 lift for the int, amd 168ish on the ex.
It will be 10.02:1 CR with forged pistons, scat crank and rods int ballanced, I have an rpm airgap, with a holley 770 avenger carb,
it also has hooker super comp 1 5/8 long tube headers. it also hasa 904 auto with a 2800 stall and extra clutches and low 1st gear set installed w/ shift kit. the Dakota also has 3:55 gears going to 3:73 8.8 phord rear 5 on 4.5 lugs soon.
it also has FBO ignition system w/out Vac advance.
what cam would be a good choice for my street drivin 96 dakota I do have the comp XE274H cam 230/236 @488/491 lift from my current old combo w/only a brake in run. would this camshaft be good or should I use a different one. I am told this cam should be ok and would idle like a stock engine. what are your thoughts. and plz tell me about the .906 cams?
it will also have P/S, breaks and a/c
thanks
Don
Dakota_Don is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Roller cam for LA motor bad_karma Dodge Ram 1 08-28-2008 03:03 PM
Fresh stroker rebuild with valve issue azzkikr B-Body 5 02-26-2008 06:02 AM
360 + melling spd-22 cam JuhKiv83 Performance parts and engine development 1 11-20-2007 08:19 AM
Cam identification, need help bcuda65 General Technical Questions 1 04-26-2007 05:38 PM
318/390 Stroker TurboSwinger New Member Section 5 02-01-2007 05:44 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
