Sponsored by:
Sponsored by:
Cant Get Valve retainers/clips When I Compress the Valve Spring
Old 09-19-2012, 08:30 PM
74Runneer's Avatar
Exclamation Cant Get Valve retainers/clips When I Compress the Valve Spring
I just got my 302 casting heads and i cant seem to get the springs off, I compress the spring and the valve just goes down with it. I tried putting carb cleaner on it and tapping the valves with a rubber mallet and nothing seems to work. Am i doing something wrong? Also can i silica sandblast all the parts (valves rockers springs and head itself) without damaging them? or how should i clean them? Thanks
Old 09-19-2012, 10:02 PM
You could media blast them with something like walnut shells. DO NOT sand blast them...
Are you holding the valve closed ?
Old 09-20-2012, 08:23 AM
70redbee's Avatar
You need a valve spring compressor tool that holds the valve closed while you compress the springs. You can buy one at Sears or any online tool dealer or parts supplier.
Old 09-20-2012, 08:43 AM
You need the large "U" shape valve spring compressor the holds the valve closed. Like before mentioned I bought one at Sears.
Old 09-20-2012, 08:47 AM
This is a common problem. The locks are wedged in the retainers is all. Pack some rags under the valves and lay the head on a wood bench. Take a piece of tube or socket and extension which will fit on the retainer and give them a sharp but not heavy blow with a hammer.
If the heads are rusted from exposure, you might first try leaving for a few days, and apply a little penetrating oil every day.
Gorts 5th (09-25-2012)
Old 09-25-2012, 12:15 PM
Gorts 5th's Avatar
Smile
yep that works for me
Old 10-17-2015, 10:07 AM
ritroutt's Avatar
no sand
You need to block the valve to keep it from moving. a regular c style valve spring compressor will solve your problem.
I recommend you find a shop that knows how to really clean parts. It's worth the money. No blasting.
Old 10-17-2015, 10:32 AM
Magoo's Avatar
Smile OLD POST
-- WELCOME -- You need to look at the date of posting. This series goes back to 2012. -- Not a problem. -- Enjoy it here.
robertherr
04-05-2012 04:37 PM
SPICOLIE203
11-23-2011 05:59 PM
chezhed
08-08-2011 07:09 PM
xjonathanx
01-30-2010 09:36 AM
v8only
06-05-2009 04:27 PM
Quick Reply: Cant Get Valve retainers/clips When I Compress the Valve Spring
