Dodge Daytona MAP Sensor HELP Greatly Appreciated
hi i have a nineteen ninety dodge daytona ES with a 3.0L SOHC 12v V6. i recently bought a performance module(resistor) and i am havin trouble figuring which wire to hook it into the map sensor and i cannot find a wiring diagram anywhere for free if anyone could plz help me there are 3 wires going to my map senson and from top to bottom the colors are orange and ???, black(pretty sure thats the ground), and Brown and white(i think its this one but dont wanna take any chances) but if any1 has any info regaurding this plzzzz let me know
ALL HAIL MOPARRRRRR |
Which wire do you need to find/hook into? Need a little more info about exactly what you are trying to accomplish. I cant tell you the wire if I dont know the function you need.:confused: Is it single point fuel injection or multi-point, turbo? According to the factory service manual, the output wire from the map to the computer should be dark green with a red trace. Wanna buy my manual?
i actually have both of the haynes manuals but dont have access to them right now but i need the IAT wire or its equivalent. the resistor sharpens the fuel curve and relays more aggresive signals to the ecu
and sorry its Multi port injected and no its not turbo, and other sources have told me that my cars equivalent to an IAT is an Air Charge sensor or ambient air sensor thanks for your help
Ok, with the multi-point FI. the middle wire is the one that feeds the info to the computer. Free-Auto-Repair-Advice: Chrysler MAP Sensor—Testing procedureIs this what you needed? Manual shows a MAP sensor. Not sure about IAT.
thank you and yes im pretty sure that that the one i need but the instructions pretty much told me that the MAP sensor has the IAT equivalent kind of in an all in one sensor but i am no sure but thank you for your help
Glad to help. The link I posted should tell you how the thing works, its good to understand how it all relates.
thank you so much ive got it all hooked up and shes running greatt
MOPAR or No car |
Glad we can help. I think I have a factory service manual for your car. Pm me if you are interested.
