Fuel Injection for '79 360 - Mopar Forums
LinkBack Thread Tools Search this Thread
Old 04-12-2010, 09:38 AM   #1
I'm thinking of puting an fuel injecton unit on by '79 360. What would be a good one to use?
79woodnick is offline   Reply With Quote
Old 04-12-2010, 10:22 AM   #2
Do you want a MPFI or a TBI setup? MPFI is great but TBI is very simple and is just as reliable.
Holley puts out a few universal kits. Take a look on Summit Racing's website.
78D200 is offline   Reply With Quote
Old 04-12-2010, 11:38 AM   #3
TBI
Old 04-12-2010, 12:57 PM   #4
Holley makes some pretty good kits but when I looked at the prices, WOW.
If you have the time you could always install a TBI setup from a later Dodge truck onto yours. maybe find one that is in a wreck for cheap and pull the setup with wiring out and install it onto yours.
Old 04-12-2010, 01:44 PM   #5
old tired rebel's Avatar
How hard would that be?
old tired rebel is offline   Reply With Quote
Old 04-12-2010, 03:12 PM   #6
thinkin with me dipstick
johnthegoalie's Avatar
if you find a wrecked ram or even a dakota r/t - grab the whole drivetrain, wiring harness and computer. hell, you can even upgrade with a new airconditioner while you're at it...
johnthegoalie is offline   Reply With Quote
Old 04-12-2010, 03:20 PM   #7
Quote:
Will the intake fit my LA 318?
Old 04-12-2010, 03:49 PM   #8
scotts74birds's Avatar
The engine would probably be the cheapest part of the equation. Might just want to start with a magnum 5.9 to insure compatibility.
scotts74birds is offline   Reply With Quote
Old 04-12-2010, 09:27 PM   #9
Its not really cheap but look at professional products power jection. It is a tbI but looks like a carb, a few simple wires for install and it tunes itself.
http://www.professional-products.com/EFI_3.php
440truck is offline   Reply With Quote
Old 04-13-2010, 02:50 AM   #10
Quote:
that i dont know but even if it bolts up getting it to run is a different story. considering the older engines don't have the provisions for all the sensors, etc that ar required to have everything run smoothly. thats why if you get the whole drivetrain including computer controlled automatic od transmission - hook everything up... old car with new car reliability...
mopar performance even has a performance computer to wake up the engine even more
Old 04-14-2010, 08:17 AM   #11
Member
K.I.S.S STAY CARB'D!!!!!!!! My son and I just brought an 89 RamCharger home from Vegas; with a 360 and that blasted crappy TBI! I am so ready to back-fit it with a TQ! TBI SUCKS! I had it in my 88 D 100 2WD shortbed with a 318 and could NOT get over 8 MPG! I wound up selling the truck since I was so tired of sppending money to improve that number! my current 83 (also 318 but 4 BBL Carter AFB) 3/4 ton gets 14 pretty easily; this Ramcharger gets 6 to 7 MPG so far and burns so freaking rich that it burns my eyes when I open a window.
volaredon is offline   Reply With Quote
Old 04-14-2010, 08:31 AM   #12
Ditto, don't waste your money on EFI, the improvements in drivability and economy will not outweigh the price and trouble of getting it installed.
For much less money you can get an intake manifold, a new carburetor, and a good ignition/distributor system.
I used to have a 1980 Dodge St Regis highway patrol car with the E58 (HP) 360 in it. The engine came equipped with a smog Thermoquad carb and the crappy electronic lean burn nonsense. The car was a mediocre performer which used a lot of gas and made less-than-spectacular horsepower.
The first thing I did was scrapped the electronic lean-burn system. I got an older vacuum advance electronic distributor and ignition control box out of an older Duster. The conversion took me about 30 minutes to complete. I got rid of the factory intake and installed a used Edelbrock performer along with an earlier model Thermoquad that I salvaged from a big New Yorker. I then swapped the 360 heads for a set of 340 2.02 heads that I had sitting in my garage, and last but not least, I installed an Erson RV15 cam.
The improvement in power (and gas mileage) was amazing, and with the intake manifold painted to match the rest of the engine, I was actually able to get the car smog tested when I registered it in California. The car passed the visual and sniffer test without a problem. The total cost for all of this (including the cylinder heads) was less than $500.
Sangetsu is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Converting to fuel injection, need help Nightmare Engines, Exhaust and Fuel systems 20 03-31-2012 11:43 AM
switching from carb to fuel injection AnthonyGW0114 Engines, Exhaust and Fuel systems 5 11-23-2011 03:00 PM
Water/Meth Injection Fratzog440 General Technical Questions 10 02-11-2011 05:55 PM
I need 360 fuel injection help cuda0872 General Technical Questions 1 09-23-2010 03:35 AM
small block fuel injection, complete kit brand new zekebracing Mopar Classifieds 0 12-28-2009 04:00 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
