Go Back   Mopar Forums > GENERAL > General Discussion
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 02-09-2008, 06:58 PM   #1 (permalink)
panelman
Junior Member
Gen1Hemi
OK i hope someone can help me i picked up a Gen1 Hemi eng#c542-8-23046 now if someone could decifer these numbers It has Chrysler Fire Power stamped in the valve covers???i am building a 1965Dart GT i already have started gathering parts car org/6 i have 23splineA833 an8.75 rearend with 323 gears the motormount tabs on the block look the same as a LA318?? will aLA318 bellhousing --flywheel xcetra fit should i bother (if parts are even avail)rebuilding this Hemi and if so can someone tell me where to get parts it has a castiron 4bbl intake on it and center dump exhaust mans any tips thoughts or other input would be greatly appreciated thanx guys
panelman is offline   Reply With Quote
Old 02-09-2008, 09:18 PM   #2 (permalink)
cudax34me
Junior Member
gen1 id
hi there.just found this site..these guys should be able to give you some info on those questions good luck and good luck. hot heads research and racing @hothemiheads.com
cudax34me is offline   Reply With Quote
Old 04-01-2008, 06:23 PM   #3 (permalink)
Mopar Guy in Delaware
Member
Hi
I believe you have an old style 354 engine, the distributor is probably in the back and the valley over the cam and tappets have a seperate cover with a spyder type cast intake above it. Probably a mid 50's to early 60's engine.
See Ya, George
Mopar Guy in Delaware is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
Dodge | Ford Mustang | Harley | Motorcycle Forums
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
