Help with headlights please!!
Old 06-19-2013, 08:25 AM
val1550's Avatar
Exclamation Help with headlights please!!
I have a 72 Challenger and after about 15-20 minutes of night time driving my headlights will go out. Keep in mind my dash, tail lights, brake lights all continue to work. It almost seems like once my car is running good and up to temp then bam... the headlights go out, stay off for a few seconds and come back on. Continually getting worse by going off and staying off for longer periods of time then come back on. Why would they work right away but go off after just a short period of time? Please help
Old 06-19-2013, 08:37 AM
This is one of about three things
First, the headlights are not fused before the power gets TO the light switch. On or in the light switch is an automatic BREAKER
1--If you have installed heavier wattage headlights, they may be drawing more current than original and the breaker may be marginally weak
2--The breaker may be marginally weak
3--The harness connector at the light switch, or even bad connections right in the switch (contacts going bad, example) may be causing HEAT which warms up the breaker and causes it to trip
This is a classic example of headlight system problems
If you wander around the www there are several ways to add headlight relays which do several things:
They are getting the heavy headlight power out under the hood, so power no longer has to go through the bulkhead connector
Relays relieve the pressure on the headlight switch, the dimmer switch, and other wiring.
You can hide these, example, under the battery box
Newtonsatellite
12-12-2013 10:32 AM
christineman
05-24-2012 06:44 PM
cjperry81
03-18-2009 05:23 PM
mahd
02-25-2009 12:02 AM
skymynx
11-17-2008 09:11 AM
Quick Reply: Help with headlights please!!
