its alive!
i just finished putting the holley 2300 on my 4bbl intake and got it fired up. seems to have a lot more throttle response than before. i was going to drive it but when i was adjusting the idle settings and the timing i noticed that it was leaking from the fuel line inlet. so off on the motorcycle to get some new o rings then a test drive.
i took it out for a ride and it seems like under heavy load it stumbles and sometimes stalls out. any suggestions?
good job getting it finished up. Sounds like you might have to adjust the mixture settings and posibly the timing some more.
any idea on how to adjust the mixture settings on it?
