Need your A/C hoses repaired with a fast turn around?
Old 06-07-2012, 09:04 PM
Well I had a good experience with Kelly at Estes Automotive in Birmingham Alabama. Two Saturdays ago I was cruising around in my Dakota with cold A/C blowing. I had a very enjoyable time. Sunday I pulled her out for antoher drive and the compressor would not turn on. I found a big mess where one of the hoses blew out.
http://autoachoserepair.com/
kelly@estesauto.com
Now my options were to find an NOS hose or after market replacement. No NOS ones were to be found. I could only get one replacement hose and it was not the one I needed. So I started the google search. A/C hose repair brought up two websites. That night I took pictures of the hoses and sent them off to both companies. Kelly with Estes Automotive was the first to reply with a price and the correct answer that my hoses could be repaired.
I sent them out Wednesday and they got them on Friday.
Old 06-07-2012, 09:05 PM
Well after stripping the paint off of them this morning this is how they look. I cleaned the rust off of them tonight and they are ready for paint tomorrow morning.
Old 06-07-2012, 09:06 PM
This is how they make the repairs.
BRAZE-ON FITTING REPAIR PROCEDURE
Verify Fitting Orientation (Fitting Clock Position) Before Starting.
Cut Tube
Clean & Braze
Use Gentle Heat For Aluminum Brazing. Bring Temperature Up Slowly and Evenly. Base Alloys Have a Melting Temperture of About 1250°F. The AFC-1000 Melts At About 1000 °F. It’s All About Controlling Your Heat.
Cut Hose Clean and Square.
Install Ferrule & Hose.
Center The Wide Opening At 90° Or 270° (3 o’Clock Or 9 o’Clock) As Shown.
I got mine all cleaned up and painted today. Glad I stayed with the stock looking ends and just had the hoses replaced.
Old 06-08-2012, 10:12 AM
Looks pretty good. I'm not sure I understand why they needed to braze anything on. Most of the time you can remove the original crimp and hose, and the barb should be still on the tube
I sure am distressed to see Ma is still using those stupid flange connectors, expecially the one with only one bolt hole. I once had an 86 Dodge 600 (car, not truck) and never did get one flange to completely seal.
Old 06-08-2012, 10:24 AM
I am not to happy with the design either. But I do like cold A/C. I like the new o-ring style sealing hoses. They did give me all new seals for each connection also. The prior hose was suitable for R-12. I am pretty sure the new synthetic R-134a ate a hole in the hose. I will put them back on tonight and put the system under a vacuum. Braze instead of just a new crimp ferrel? I think the new hose inside diameter is different. Look close at the original hoses.
Old 06-08-2012, 10:29 AM
mikerp76's Avatar
be sure to blow out the evaporator, and condensor. plus flushout the a/c compressor while you at it. also there are a few oriellys that make a/c hoses.you just have to cut the collar off of the old hoses and reuse you end fittings.
Old 06-08-2012, 10:41 AM
A/C compressor is brand new with 100 miles on it. It was just a hose failure. When I got the new compressor on I flushed out the entire system with A/C flush. I have a new drier that I installed. I will blow out the hoses once more before I install them.
Old 06-08-2012, 10:43 AM
mikerp76's Avatar
ok but the reason i said to flus it out was to make sure there wasn't any hose material from the failure point in the compressor.
Old 10-13-2013, 07:46 AM
airmechanical's Avatar
AC Repair Houston Tx
If you are in texas, let me know you Air United Mechanical provides your high class AC Repair services have a look. it might be helpful for you. thanks
Old 10-13-2013, 08:00 AM
Agree X2. I'm not an expert on the parts available for automotive AC, but when was in commercial HVAC, it was routine to install filters in the suction line on a compressor change, where the old compressor (or in this case hoses) might have introduced debri or contaminants into the system.
Back when I was in auto parts, the shop guy and I developed a similar method for power steering hoses. We stocked and sold a large array of industrial / tractor hydraulic hoses and fittings. This was before Weatherhead or others had come out with the hose ends / compression fittings to repair tube ends (06U-756, etc)
I took a JIC (AN) flare adapter, sawed off one end, countersunk a hole the size of the tube, and we brazed it onto the original tube end of a bad PS hose. Then just a simple matter of making up a hose with a common JIC hose end to fit.
Hell we made hundreds of those. Of course they don't quite look factory, so not the thing for "restore correct."
Old 07-02-2015, 02:41 AM
chillywilly's Avatar
Fast AC Repair Houston TX
Hello sir
I read your article I fully understand your work. I am so excited for looking this blog and agree with you. We have also doing this work ago some years. I appreciate to you. If you wants some discussion to me then you will contact us. Our official website. www.chillywillyhvac.com
RacerHog
05-11-2014 06:28 AM
ottosen@chorus.net
01-26-2014 06:09 PM
DMV
05-10-2011 10:22 PM
bc18
07-22-2009 04:16 PM
Kevin71
02-11-2009 07:51 AM
Quick Reply: Need your A/C hoses repaired with a fast turn around?
