Oil type
I have been told that i should be using a zinc additive in my oil, is this true? If so does anyone know where I can pick sone up?
Lucas makes an additive... And there are many others..Rotella T is zinc enriched oil..Most diesel oils are... You need the zinc if you are running flat lifters/tappets to save the wear on the camshaft...There are also specialty oils made for older technology engines but are ridulously priced and you get the same thing in fleet oil....Bill
Ok good thanks. I did change the oil recently and I did use the rotella t brand. I was glad you said that brand, so I didn't have to drain it and add something else. Thank you again.
Vinnie |
wrong oil
Well I just found out what happens when you use the wrong oil in these older engines. I was getting ready to put on my intake, I took off the vally pan and the cam shaft, lifters, push rods and rockers are toasted. everything is pitted, and the cam shaft has even got some flats on it. this father son project car just got exspenssive.
check out ZDDplus.com it has your zinc. been using it for years. do NOT believe all thats said to not use addives, some times it is ok.
If you can afford it ? upgrade to roller lifters
If you use a flat tappet cam when you replace the one that is toast make sure you follow the breakin process to the letter...alot of people have ruined new cams not following the proceedure...Lucas additive has a failure/replacement warranty...Bill
using the rottella oil used to be a option but there have been recent changes to this oil and its not good to use it for that anymore.If you want to protect your flat tappet cam during break in . be sure its clean then spray it with a graphite lube some engine builders are doing this now the graphite gives the cam a texture that the assembly lube sticks to better and wont come off so fast, spray the bottom of lifters too then apply lube.as far as oil goes Kendall 20-50 has been my oil in my mopar always alot of old school mopar guys like myself have used it for years it has the added zinc you need.Kendall has always been a preformance based company and a supporter of mopars.Give it a try
Originally Posted by Hot Rod Dave
(Post 115065)
Yea bill the label on this oil reads as follows--specially forumalted for competion engines and hi preformance street engines including those with flat tappet camshafts contains high level of zddp plus kendalls liquid titauium additive.its a super good oil and is around $6 bucks a guart
Thanks Dave...Bill
BE safe and just use a zinc additive. It's cheap insurance.. Rotella is still a good oil. does not have as much zinc as it had in years past
no problem bill its good to share info on products that have proven themselves.I once saw a piston out of a motor that had blown up badly it had a floating pin and the rod was twisted and had been sitting outside beside this guys garage in a pile of old parts for several years in the weather and the pin still moved like the day it was removed free as it could be that motor had only used kendall oil in it
Thank you all for the great info, I am still not sure if I am going to stick with flat tappet or up grade to a roller cam just doing a lot of research right now.
Originally Posted by 1968GTX
(Post 115089)
open wallet wide |
Originally Posted by moparted
(Post 115098)
open wallet wide
oil type
Thanks for asking this question, I have a 1973 Dart Swinger with a 318 with a 340 setup and have been using Castrol GTX 10W 40, should I use something different on my next oil change? I live in SC where the weather is very mild now and hot in the sunmmer.
Thanks |
